Robotics
Robotics
Blog Truss Navigating Robot
  • Author Author: Eavesdropper
  • Date Created: 6 Mar 2012 8:00 PM Date Created
  • Views 719 views
  • research
  • industrial
  • autonomous
  • robotics
  • robots
  • robot
  • on_campus
  • behavior
  • eavesdropper
  • school
  • university
  • automation
  • sensor
Eavesdropper
Eavesdropper
6 Mar 2012
A group of researchers from Cornell Creative Machine Labs are currently developing an autonomous robot inspired from metabolisms of biological organisms. The goal is to be able to break down larger complex structures into smaller simpler pieces that may be reassembled to create a different type of structure.
The robot clamps onto a specially designed truss using rotational robot-lockable connectors and can traverse the three dimensional structure using three basic motions. Bi-directional gears on the robot allow it move between perpendicular planes, horizontally and vertically along a truss, and 180 degrees around a truss to move from the top to the bottom. In addition, reflectivity sensors are implemented into the robot which give it a sense of location relative to the truss structure, ultimately allowing it to function autonomously.
The sensors and movements are all controlled from on board the robot. The robot carries with it a sensor I/O board, a microcontroller, servo motors, and an on board battery. These simple electronics allow it detach truss beams with 100 percent success rate and reattach them with a 70 percent success rate.
While they would like to use the robot for building deconstruction and repair, that does not stop the researchers from thinking big. One day they hope that it could help repair and construct the space station or any other dangerous tasks associated with the outside of the space station or a shuttle. Meanwhile, the researchers will be working on improving the robot so it will be cable of carrying multiple truss beams at once, and they plan on re-working the algorithms that will allow it to traverse a path of most efficiency based on the final design.
Eavesdropper
    DAB over 14 years ago
    Hi E,
    I like it.  This is the first approach to a construction Waldo that SciFi has been pushing for decades.  You could link these together with the Swarm Bot networks for construction, demolition, mining, dredging, and a ton of uses for exploiting the solar system.
    Neat!
    Hi E,
    Neat!
