Robotics
Robotics
Forum Transparent wire
  • Subscribers 78 subscribers
  • Views 1573 views
Transparent wire
I was wondering if anyone out there knows of a transparent conductor, preferably in the form of wire. Any input is greatly appreciated.image
    shabaz over 10 years ago +2
    More information is needed. What level of conductivity? If not in the form of a wire, what other forms are acceptable? What properties of the wire were you interested in? Wire is metal, which is not transparent…
    shabaz over 10 years ago in reply to johnbeetem +2
    I mistakenly thought ITO was deposited just on glass, but looks like Adafruit claim to offer it on flexible transparent plastic sheet. But they have some stock issue maybe, since they mention 1 per customer…
    balearicdynamics over 10 years ago +1
    I think you should orient your search in the direction of the materials used by the conductive - years ago, before capacitive one - touch screens. I played for years with a reversi pocket game with a small…
    Wire is metal, which is not transparent when in a solid wire form. However liquids in a clear plastic tube can be conductive. Did you just mean a cylindrical form? What diameter?
    Does it have to be transparent like windows, or just translucent? Or can it approximately look transparent from a distance due to use of thin wire strands? What is the end application?
    Are you transferring power, or signals conveying information?
    I think you should orient your search in the direction of the materials used by the conductive - years ago, before capacitive one - touch screens. I played for years with a reversi pocket game with a small touch screen over ths B/W LCD display where the wires was visible only in transparence and was zero impact when playing.
    Enrico
  • johnbeetem
    johnbeetem over 10 years ago
    Capacitive touch screens use indium tin oxide, a transparent conductor.  It's also used for LCDs and other transparent conductive applications.  I've usually seen it as a 2-D layer rather than a wire, though I believe it's etched like PC board copper so you can have "printed wires" to use old-fashioned PCB terminology.
    I mistakenly thought ITO was deposited just on glass, but looks like Adafruit claim to offer it on flexible transparent plastic sheet. But they have some stock issue maybe, since they mention 1 per customer on their page.
    e14 Contributor over 10 years ago in reply to shabaz
    Sorry for the lack of information, I am new here so I really have no idea what the heck I'm doing : / . I was looking for a very thin conductor that was somewhat clear up close, the clearer the better. The voltages would be very small, at maximum around 2 volts. I apologize for the vagueness, and I greatly appreciate your guys' feed back. I apologize for the long response time, but being in school and all I haven't had much time for my email. Thanks again for your patience.
