Robotics
Robotics
Forum Current Loop Control with RS-485/Modbus interface
  • Subscribers 76 subscribers
  • Views 1278 views
Hi There,
I would like to get some recommendations on a new design I am working on. I have never interfaced these current loops and just want to make sure I am going about this in the most efficient manner.  I have the task to create a control board will run a control loop from a 4-20mA sensor to a DSPIC controller and outputs a 4-20mA current loop to control a proportional valve.  The system needs to be able to interface on a RS-485 bus.
I have found that there are some pretty nice ICs that contain most of the circuitry to A/D and D/A the current loops.  I have found some interface chips that seem like they will do the job for what I need.  I am hoping to get some feedback for whether these will indeed most efficiently do the job for what I need, or if not I would hope to get some feedback to get me on track.
Here are the parts that I am thinking of using:
4-20mA current loop A/D:  AD7707
4-20mA current loop D/A: AD421
RS-485 2 wire transceiver: SN65HVD1782D ( not available through element 14)  Hopefully you can recommend a part from here that will work.
Controller:  PIC33F micro
Thanks for any insight you may have for me.
    After looking further into this it looks like the parts that I have chosen are very old.  I am wondering if someone can please fill me in on what the general way that current loops are being implemented these days.
    Can someone please list how they would recommend building a current loop receiver and transmitter?  Discrete components?  IC's.
    It looks like the receiver end would be straight forward enough using a precision resistor and an opamp?  Can anyone elaborate on any pitfalls associated with this?  What about the transmitter end?
    Thanks in Advance.
    No sure what the lack of response implies.  I did find a very comprehensive article from circuit cellar "The 4-to-20-mA Current Loop" Aug 2010 #241, p.28.  This article was the most helpful resource I could find out there in regard to the use of current loops.  I had scoured through many app notes and this seemed to be the most conclusive on use of transmitters, receivers.
    Know it may a bit late for a reply, but your posts have helped me out and felt like they needed appreciating.
    You can download copies of the aritcles from the cc website, http://www.dtweed.com/circuitcellar/caj00241.htm
