Robotics
Robotics
Forum Industrial Conformance Test
  • Subscribers 75 subscribers
  • Views 340 views
  • industrial
  • tests
  • standarts
  • rtu
We are planning to develop an RTU device to be used in medium voltage industrial environments.
When i research some about this topic, there are couple of hardware tests for industrial equipments. Such as;
    • Radiated immunity,
    • Radiated emissions,
    • Conducted immunity,
    • Conducted emissions,
    • Electrostatic discharge (ESD) immunity,
    • Burst immunity,
    • Powerline dip immunity,
    • Powerline surge immunity,
Also there are lots of international standarts for such devices to used in this kind of environments. Such as;
    1. IEC 60870-5-6 Guidelines for conformance testing for the IEC 60870-5 companion standards
    2. IEC 61850-3: General requirements
    3. IEC 61850-10: Conformance testing
    4. IEC 61000-4-2 Electromagnetic compatibility (EMC) - Part 4-2: Testing and measurement techniques - Electrostatic discharge immunity test
    5. IEC 61000-4-3     Electromagnetic compatibility (EMC) - Part 4-3: Testing and measurement techniques - Radiated, radio-frequency, electromagnetic field immunity test
    6. IEC 61000-4-4 Electromagnetic compatibility (EMC) - Part 4-4: Testing and measurement techniques - Electrical fast transient/burst immunity test
    7. IEC 61000-4-5 Electromagnetic compatibility (EMC) - Part 4-5: Testing and measurement techniques - Surge immunity test
    8. IEC 61000-4-6 Electromagnetic compatibility (EMC) - Part 4-6: Testing and measurement techniques - Immunity to conducted disturbances, induced by radio-frequency fields
    9. IEC 61000-6-2 Electromagnetic compatibility (EMC) - Part 6-2: Generic standards - Immunity for industrial environments
    10. IEC 61000-6-4 Electromagnetic compatibility (EMC) - Part 6-4: Generic standards - Emission standard for industrial environments
    11. IEC 61000-6-5 Electromagnetic compatibility (EMC) - Part 6-5: Generic standards - Immunity for power station and substation environments
    12. IEC 61000-4-12     Electromagnetic compatibility (EMC) - Part 4-12: Testing and measurement techniques - Ring wave immunity test
    13. IEC 61000-4-16 Electromagnetic compatibility (EMC) - Part 4-16: Testing and measurement techniques - Test for immunity to conducted, common mode disturbances in the frequency range 0 Hz to 150 kHz
    14. IEc 60068-2-1 Environmental testing - Part 2-1: Tests - Test A: Cold
    15. IEC 60068-2-2 Environmental testing - Part 2-2: Tests - Test B: Dry heat
    16. IEC 60255-5 Electrical Relays - Part 5: Insulation coordination for measuring relays and protection equipment - Requirements and tests
    17. IEC 60255-21-1 Electrical relays - Part 21: Vibration, shock, bump and seismic tests on measuring relays and protection equipment - Section One: Vibration tests sinusoidal)
    18. IEC 60255-21-2 Electrical relays - Part 21: Vibration, shock, bump and seismic tests on measuring relays and protection equipment - Section Two: Shock and bump tests
    19. IEC 60255-21-3 Electrical relays - Part 21: Vibration, shock, bump and seismic tests on measuring relays and protection equipment - Section 3: Seismic tests
    20. IEC 60870-2-1 Telecontrol equipment and systems - Part 2: Operating conditions - Section 1: Power supply and electromagnetic compatibility
    21. IEC 60950-1 Dielectric
    22. IEC 60950-1 Impulse Voltage
    23. EN 50081-2 Conducted and Radiated Emissions
    24. EN 55024 Information Technology Equipment – Immunity characteristics
I am not an expert on this subject. I just want to find best and optimized method to obtain just the neccesary information about this subject, not more than that. I need and expert suggestion about how to proceed? Thank you in advance.
Huseyin Sahin
