Robotics
Robotics
Forum vision guided robot  using android and arduino
  • Replies 11 replies
  • Subscribers 77 subscribers
  • Views 1630 views
i am doing vision gudied robot with arduino and android through bluetooth communication . i have done the image processing part using andriod.But i am facing problems in image processing. The colored image is getting transformed to black and white image. but the code that is written to detect the black tape is not working properly.. Could some one help me to debug.
public class DrawOnTop extends View
          BtConn btcon;
          //Display
          Bitmap mBitmap;
          Paint mPaint;
          int mImageWidth, mImageHeight;
          //Frame data
          byte[] mYUVData;
          int[] mRGBData;
          int[] mBWData;
          //FPS
                    long lastFrame = System.currentTimeMillis();
                    //PID
                    float proportional;
                    float integral;
                    float derivative;
                    float last_proportional;
                    int Kp=1;
                    int Kd=2;
                    int Ki=0;
                    //Motor Controls
                    int right_speed=0;
                    int left_speed=0;
                    int max_speed = 255;
          //Line Tracking
          static int tracking;
          int minPixels = 10;
          int threshold = 60;
          int tapeCenter;
    public DrawOnTop(Context context) {
        super(context);
        // Start off PAUSED
        tracking = 0;
        mPaint = new Paint();
        mPaint.setStyle(Paint.Style.FILL);
        mPaint.setColor(Color.RED);
        mPaint.setTextSize(25);
        mBitmap = null;
        mYUVData = null;
        mRGBData = null;
    @Override
    protected void onDraw(Canvas canvas) {
        if (mBitmap != null)
                  int canvasWidth = canvas.getWidth();
                  int canvasHeight = canvas.getHeight();
                  grayscaleToBlackWhite(mRGBData, mYUVData, mImageWidth, mImageHeight,canvas);
                  int tapeCenter=DetectingArea(canvas,mRGBData, mImageWidth, mImageHeight);
                  //PID
                        proportional = tapeCenter - mImageHeight/2;
                        integral = integral + proportional;
                        derivative = proportional - last_proportional;
                        last_proportional = proportional;
                        int lineError = (int)(proportional * Kp + integral * Ki + derivative * Kd);
                        // Restricting the error value between +/- max_speed.
                        if (lineError< -max_speed)
                                  lineError = -max_speed;
                        if (lineError> max_speed)
                                  lineError = max_speed;
                        // If error_value is less than zero calculate right turn speed values
                        if (lineError> 0)
                        right_speed = max_speed + lineError;
                        left_speed = max_speed;
                        // If error_value is greater than zero calculate left turn values
                        else
                    right_speed = max_speed;
                        left_speed = max_speed - lineError;
                        int[] data = new int[3];
                        data[0] = 0; //Forward
                        data[1] = right_speed;
                        data[2] = left_speed;
                  long curFrame = System.currentTimeMillis();
                  float fps = 1000/(curFrame - lastFrame);
                  lastFrame = curFrame;
                  // Draw bitmap
                  mBitmap.setPixels(mRGBData, 0, mImageWidth, 0, 0, mImageWidth, mImageHeight);
                  Rect src = new Rect(0, 0, mImageWidth, mImageHeight);
                  Rect dst = new Rect(0, 0, canvasWidth, canvasHeight);
                  canvas.drawBitmap(mBitmap, src, dst, mPaint);
                  canvas.rotate(-90, canvasWidth/2, canvasHeight/2);
                  canvas.drawText(mImageWidth + "x" + mImageHeight, 200, -140, mPaint);
                  canvas.drawText("fps: " + fps, 500, -100, mPaint);
        super.onDraw(canvas);
    public void grayscaleToBlackWhite(int[] rgb, byte[] yuv420sp, int width, int height, Canvas canvas)
              final int frameSize = width * height;
              for (int pix = 0; pix < frameSize; pix++)
                        int pixVal = (0xff & ((int) yuv420sp[pix])) - 16;
                        if (pixVal < threshold)
                                  pixVal = 0;
                        else
                                  pixVal = 255;
                        rgb[pix] = 0xff000000 | (pixVal << 16) | (pixVal << 8) | pixVal;
  public int DetectingArea(Canvas canvas,int rgb[],int height, int width)
            int start=-1;
            int stop=-1;
            int tmpStart=-1;
            int tmpStop=-1;
          int scanline=-1;
            for(int i=0;i<width;i+=10)
                                for(int j=0;j<height;j++)
                                          //check for black line only.
                                          //find all black line centres and compare with the centre of the screen
                                          int pixVal = (0xff & (int) rgb[i+j*width]);
                                          if (pixVal == 0)
                                                              if(tmpStart==-1)
        tmpStart=j;
                                                              else
        tmpStop=j;
        if(tmpStop-tmpStart>minPixels &&
        (Math.abs((tmpStop-tmpStart)/2 - height/2)
        <  Math.abs(stop-start)/2 - height/2))
        start=tmpStart;
        stop=tmpStop;
        scanline=i;
        else
        tmpStart=-1;
        tmpStop=-1;
            if (start > -1 && stop > -1 && scanline >-1) {
                        for (int pix = start; pix <= stop; pix++) {
                                        rgb[scanline+pix*width] = 0xff000000 | (0 << 16) | (255 << 8) | 0;
            return (start+stop)/2;
    e14 Contributor over 13 years ago in reply to Ramu
    Actually i need to avoid white line and not black. I am not doing a line follower. I am ding a robot which will move forward with in a boundary and by avoiding the obstacles.The boundary line may be of black or white.Robot should not cross the buondary. As first step to my project i am trying to do a line follower.So that i could get knowledge about image processing and communication part which makes it easy to my original project
