Robotics
Robotics
Forum designing a motorized shoe.............
  • Replies 7 replies
  • Subscribers 76 subscribers
  • Views 1633 views
  • robotics
  • projects
  • motors
Iam an electrical graduate.Iam doing a project out of my own intrest.Iam intrested in designing a motorized shoe.If Iam about to use 12v supply from a battery,then which motor should i use? what should be its RPM? It should overpower a weight of 80kgs. Speed is not the concern,as it a motorized shoe,a low medium speed is enough.so, please help me.
    dougw over 12 years ago in reply to e14 Contributor +1
    These gear motors come from vehicles with big windshield wipers. Maybe you can fin a cheap used motor at a junkyard or surplus store.
    You will need a 1/3 to 1/2 HP gearmotor that rotates between 30 and 60 rpm.
    Something like this might come close ... - note you may need 60+ Amps...
    Robot MarketPlace - AME 226-series 12V 325 in-lb LH gearmotor - long shaft
    e14 Contributor over 12 years ago in reply to dougw
    Exactly thats what Im looking for,but its too expensive.can you please get me some alternate.
    Thanking you
    Can I use this motor
    20 RPM Gear Motor
    Does every windshield wiper is of similar specification to the one which you have suggested me earlier?
    This would supply about 4 kg thrust to rollerblade wheel, assuming no friction in the bearings.
    It would stall going up a 3 degree slope.
    Wiper motors have a range of sizes, but should all have enough torque to push you on a flat surface as long as the friction is low.
