Robotics
Robotics
Forum How to make a drone follow you around?
  • Subscribers 77 subscribers
  • Views 646 views
bradnorwood
bradnorwood over 11 years ago
for audio and camera controls etc.
  • Anonymous-237891
    Anonymous-237891 over 11 years ago +2
    I would advice you to take a look at OpenCV. OpenCV | OpenCV This is a library which make the use of image processing algorithm not too hard. Here is a quick install guide that I wrote : How I made Open…
  • jrmaximus
    jrmaximus over 11 years ago +1
    Hi Brad Not sure exactly what you are wanting but have you considered using a setup that works somewhat like smart missiles use, where an infrared spot is pointed at the target and a camera just has to…
  • Anonymous-237891
    I would advice you to take a look at OpenCV.OpenCV | OpenCV
    How I made Open-Cv working with XCode on my mac | Ben's things & thoughts
    (sorry for windows users but it is quite the same)
    Then you can find some algorithm which can detect your face or some couloured shape. (search Haar detect in google)
    Once you made that works on your computer with your webcam, go buy a raspberry pi and a webcam.
    OpenCV does work with python so it should be straight forward to convert your C code into Python.
    Finally you have to learn how to communicate between your Raspberry and your quadrotor controller, it use some kind of wierd protocols used in RC remote controller.
    On that point I can't help since I have never tried this out yet.
    Hope I helped !!
    Good Luck in your project.
  • bradnorwood
    bradnorwood over 11 years ago in reply to Anonymous-237891
    Ahh, thx for the info! I'll study up on this...
  • jrmaximus
    Hi Brad
    Not sure exactly what you are wanting but have you considered using a setup that works somewhat like smart missiles use, where an infrared spot is pointed at the target and a camera just has to keep track of that spot.
    I have thought about this before to get a pro video camera to track a scene by having either a infrared spot project on the target or have a somewhat concealed infrared LED on the target. A low res. camera able to see the infrared or perhaps a matrix of infrared sensors can be used to do the tracking. The infrared can be distinguished from other stray infrared perhaps by making it pulse at a set rate.
