Robotics
Robotics
Forum Robocon_Contest
  • Subscribers 77 subscribers
  • Views 1053 views
Robocon_Contest
https://m.youtube.com/watch?v=oUflmgLoil0
What's your idea about making this type of Robot?
How can we exactly put soft saucer one above other.
Any ideas regarding this topic will be highly appreciable.
Thank you.
    0 DAB over 9 years ago
    Set up a small circular table or bar stool and try to toss a Frisbee onto it.
    That set up will give you a similar experience an let you judge how well your skill set matches the challenge.
    0 e14 Contributor over 9 years ago
    hey i am ashish patel ,i think robot are very advance idea ..
  • grahamwebberjhb
    0 grahamwebberjhb over 9 years ago
    I built a toy to shoot soft spongy discs a while back and was impressed with the repeat ability of the outcome.
    It was simply a motor spinning a remote control car wheel (orange disc below). the green disc is fed into the spinning wheel the wheel accelerates it forward through the low friction guild channel (blue).
    The disc leaves the channel spinning this spin made the discs float like a frizby does, this float at the end of the trajectory is probably your best bet at plopping one disc on top of another.
    One final thought, if you consider a frizby: when it is thrown flat, parallel to the ground, it has that float at the end of the trajectory, but if its thrown skew it dives down hard, this may be a nice option for knocking off opponents discs.
