Robotics
Robotics
Forum Pleaseee A.S.A.P
  • Replies 12 replies
  • Answers 12 answers
  • Subscribers 77 subscribers
  • Views 3485 views
  • robotics
Pleaseee A.S.A.P
silentknight14th
silentknight14th over 8 years ago
I am making a study on robotics that uses a radar.
but I don't know;
what type of sensor is used in making radars?
like radar on a ship.
Can a radar like that map a certain area? or it needs an overlaying of an electronic chart or map?
thank you, please helpppppppp meeeeeeeeeee...
    jw0752 over 8 years ago +8 suggested
    Hi Raymond, You may want to Google LIDAR which is similar to RADAR but uses pulsed laser to detect objects and surroundings. Ultrasound and PIR are also useful sensors for robots. Radar can be used but…
    DAB over 8 years ago +7 suggested
    Typically radar refers to radio frequencies. In Robotics you will find ultrasonic sensors for short distance (0-2 meters) measurements and Lidar for longer distance (.02 - 100 meters) measurements. There…
  • silentknight14th
    silentknight14th over 8 years ago in reply to jw0752 +5 suggested
    Thank you for your suggestion. I'm gonna search for it.
  • jomoenginer
    0 jomoenginer over 8 years ago in reply to silentknight14th
    silentknight14th  wrote:
    Thank you,
    I have been searching a lot for some sensor
    I was inspired by the radar which marines used and those sea mark that appears on their radar.
    I was going to place it in land, but buying a marine radar would cost so much, and i want to find an alternative a much cheaper one.
    Which can cover large distance, do you have a suggestion for me? Thank you.
    Uh, is this not a red flag for some folks?
    For the poster, I would suggest doing a Google search, but if you are unable to find any specifics regarding this technology then it is a good clue that companies more than likely would not like the data to reach the wrong hands.
    Personally I would caution anyone looking to providing info in this thread especially if it is something they had worked on in the past. Just saying.
    • Vote Up +5 Vote Down
    0 DAB over 8 years ago in reply to silentknight14th
    Hi Raymond,
    Trust me, a lot of people have been looking for a cheaper way to do what you want.
    Many things have been tried, but so far nothing has demonstrated that it is a reasonable solution.
    Engineering 101, define carefully what you want to do.
    Find something that is acceptable for your specific application.
    Build and test.
    In the 100 meter range the Lidar will work and costs roughly 100 USD to get a reasonable sensor.
    RF sensor suffer from near field issues, so a traditional radar at those ranges would actually be more expensive and less reliable.
    If a sensor exists for that range the is better or cheaper, then it is being kept quiet.
    Still it does not hurt to think about the options. You might be able to use a pin diode with a directional antenna, but you will have to do some testing on frequencies and power ratings.
    Don't forget, any RF emissions fall under strong legislation about interference, so unless you have a good quality anechoic chamber to work in, you probably should not be working in free space.
    These are not simple issues.
