Robotics
Robotics
Forum Pleaseee A.S.A.P
  • Replies 12 replies
  • Answers 12 answers
  • Subscribers 77 subscribers
  • Views 3484 views
  • robotics
Pleaseee A.S.A.P
silentknight14th
silentknight14th over 8 years ago
I am making a study on robotics that uses a radar.
but I don't know;
what type of sensor is used in making radars?
like radar on a ship.
Can a radar like that map a certain area? or it needs an overlaying of an electronic chart or map?
thank you, please helpppppppp meeeeeeeeeee...
    jw0752 over 8 years ago +8 suggested
    Hi Raymond, You may want to Google LIDAR which is similar to RADAR but uses pulsed laser to detect objects and surroundings. Ultrasound and PIR are also useful sensors for robots. Radar can be used but…
    DAB over 8 years ago +7 suggested
    Typically radar refers to radio frequencies. In Robotics you will find ultrasonic sensors for short distance (0-2 meters) measurements and Lidar for longer distance (.02 - 100 meters) measurements. There…
  • silentknight14th
    silentknight14th over 8 years ago in reply to jw0752 +5 suggested
    Thank you for your suggestion. I'm gonna search for it.
    0 jw0752 over 8 years ago
    Hi Raymond,
    You may want to Google LIDAR which is similar to RADAR but uses pulsed laser to detect objects and surroundings. Ultrasound and PIR are also useful sensors for robots. Radar can be used but since it is more sensitive to metal and reflective object I am not sure how applicable it would be to a general purpose robot. I am not an expert so perhaps some of the other guys on the forum will also render their opinions.
    • Vote Up +8 Vote Down
  • silentknight14th
    0 silentknight14th over 8 years ago in reply to jw0752
    • Vote Up +5 Vote Down
    0 DAB over 8 years ago
    There are some experiments going on with millimeter wave sensors, but those are not usually associated with robots yet.
    So using the term radar with robots seems odd as there is limited utility.
    Now if you are talking about aerial vehicles, they you will find radar included as a part of the avionics package, but you are not talking about inexpensive robots in this case.
    So I suggest you supply us with additional information to narrow the context of what you want to know.
    • Vote Up +7 Vote Down
    0 e14 Contributor over 8 years ago
    I got involved in robots when I was younger, back then we used to use sharp ir rangefinders https://www.robotshop.com/uk/sharp-gp2y0a21yk0f-ir-range-sensor.html  and mount them to a servo so they could scan an area. Theres lots of different rangefinders with different distance capabilities.
    Because light doesnt spread as much as sound they were more precise than ultrasound.
    The radar you see on ships require a lot of radio energy to work, so much so that the radar units have to be disabled when the ship is in port to prevent risk of cancer to anybody in its close field, theyre usually mounted high enough to avoid the radio waves affecting the crew on board, it just goes over them.
  • silentknight14th
    0 silentknight14th over 8 years ago in reply to DAB
    Thank you.
    I was confused too, our school named it robotics but I find it hard to conclude that it is robotics rather than it is a mechanical and electronics thing.
    I am thinking of a design of a device that can be used in forestry regions.
    and can monitor such things.
    so I decided to use a radar, but I don't know what kind.
    so Lidar can cover a distance up to 100 meters?
    is there any similarities on programming of lidar and ultrasonic sensors?
    and how much is the cheapest one?
  • fmilburn
    0 fmilburn over 8 years ago in reply to silentknight14th
    I suggest watching this video on less expensive lidar units as well as a description on how lidar works: https://m.youtube.com/watch?v=ddxguAzzzJE
    He also has videos on how to program various distance measurement sensors including ultrasonic sensors.
  • silentknight14th
    0 silentknight14th over 8 years ago in reply to e14 Contributor
    thank you
    but
    can I also use a microwave sensor? to cover like a hundred meters of distance?
    0 jw0752 over 8 years ago in reply to silentknight14th
    Hi Raymond,
    Each type of radiation has its own absorption and reflection characteristics. Microwaves are a frequency that is easily absorbed so they may not make a good radiation for scanning. This is why they are used in microwave ovens. You would send the waves out and rather than reflecting back to your sensor they would be absorbed by the environment. You will have to determine the material in the environment that you want to detect and to what precision and then select the type of radiation that will best serve your needs.
  • silentknight14th
    Thank you,
    I have been searching a lot for some sensor
    I was inspired by the radar which marines used and those sea mark that appears on their radar.
    I was going to place it in land, but buying a marine radar would cost so much, and i want to find an alternative a much cheaper one.
    Which can cover large distance, do you have a suggestion for me? Thank you.
    Hi Raymond,
    Sorry I understand some of the physics but I have almost no experience with the type of sensor you are looking for. Some of your challenge may be that you are not real specific on what you want to sense. Unless you have AI level processing power available do not expect to be able to sense the world like we can with our eyes. Most robotic systems are geared to object avoidance or object targeting. Most robots use more than one sensing system to allow them to do better in special situations. You may want to study up on autonomous vehicles to see what type of sensors they are using. My robot vacuum cleaners in my home use LIDAR, touch, and I suspect Infrared sensors in their systems to navigate the house.
