Robotics
Robotics
Forum Optical sensor to measure rotation speed
  • Subscribers 65 subscribers
  • Views 661 views
Hello!
We 're looking for an optic sensor to measure the rotation speed on a little wheel (10cm diameter) in Y shape.
The rotation speed will be between 0 and 3000 rotation per minute, and we need to have the speed twice per second.
The measurement will be made by a MC9S08DZ128 microcontroller connected to this optic sensor.
Thank you for your answer.
Fabian
  • Oliver
    0 Oliver over 16 years ago
    It is difficult to find a specific part number to you, you can click the following links to choose the best one that you want.
    http://www.newark.com/jsp/search/results.jsp?N=500003+1000026&No=50&Ntk=gensearch_001&Ntt=encoder&Ntx=
    http://uk.farnell.com/jsp/search/browse.jsp?N=500006+1004249&Ntk=gensearch_001&Ntt=Optical+encoder&Ntx=
    Also, you can contact local technical support engineer.
    thanks & best regards;
    oliver
    0 e14 Contributor over 16 years ago
    Are you set on an optical or would another type be ok? Such as a metal-sensing inductive sensor.
    Ok thank you Oliver, we'll try this optic sensor : AEDR-8300
