Robotics
Robotics
Forum Nema4 Enclosure, need an inexpensive option
  • Replies 10 replies
  • Subscribers 78 subscribers
  • Views 1757 views
  • enclosure
Catwell over 16 years ago
I need a Nema4 enclosure roughly 10" x 10" x 6" for less than $50 US dollars.
Let me know where I can get one, or where to look.
Thanks.
Cabe
    0 e14 Contributor over 16 years ago
    Try Newark,
    http://www.newark.com/jsp/search/browse.jsp?N=500003+1000713+138772+188214+109822&Ntk=gensearch_001&Ntt=nema+4&Ntx=mode+matchallpartial&No=0&getResults=true&appliedparametrics=true&locale=en_US&catalogId=&prevNValues=500003+1000713&filtersHidden=false&appliedHidden=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D500003%2B1000713%26Ntk%3Dgensearch_001%26Ntt%3Dnema%2B4%26Ntx%3Dmode%2Bmatchallpartial%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_US%26catalogId%3D%26prevNValues%3D500003%2B1000713
  • ASano
    0 ASano over 16 years ago
    Hi
    The enclouser have the grade IP66 = NEMA 4X, see the link.
    http://us.element-14.com/jsp/search/browse.jsp?N=1000050+500002+189547&Ntk=gensearch_001&Ntt=ip66&Ntx=mode+matchallpartial&No=0&getResults=true&appliedparametrics=true&locale=en_US_E14&catalogId=&prevNValues=1000050+500002&filtersHidden=false&appliedHidden=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D1000050%2B500002%26Ntk%3Dgensearch_001%26Ntt%3Dip66%26Ntx%3Dmode%2Bmatchallpartial%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_US_E14%26catalogId%3D%26prevNValues%3D1000050%2B500002
    The enclouser with the grade NEMA 4 = IP65, see the link
    http://us.element-14.com/jsp/search/browse.jsp?N=1000713+173733&No=0&getResults=true&appliedparametrics=true&locale=en_US_E14&catalogId=&prevNValues=1000713&filtersHidden=false&appliedHidden=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D1000713%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_US_E14%26catalogId%3D%26prevNValues%3D1000713
  • Catwell
    0 Catwell over 16 years ago in reply to ASano
    These are all great options. However, the metal enclosures are not sealed enough for my electronics.
    I need a box like this here, but I would like it to be half the price. $60 is just too much money for a box. Any options out there?
  • ASano
    0 ASano over 16 years ago in reply to Catwell
    Hi
    for your application see this link
    http://www.newark.com/jsp/search/browse.jsp?N=1000713+173735+173739+5027468+173714+173715+173716+173717+139390+139391&No=0&getResults=true&appliedparametrics=true&locale=en_US&catalogId=&prevNValues=1000713+173735+173739+5027468+173714+173713+173715+173716+173717+173718+139390+139391+173730+173733+173736+173710&filtersHidden=false&appliedHidden=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D1000713%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_US%26catalogId%3D%26prevNValues%3D1000713
    They are IP66/67 and NEMA certificate same your example.
    0 e14 Contributor over 16 years ago in reply to Catwell
    I would suggest giving the company you posted a call. As a salesman, I would negotiate a price!
  • jhaas
    0 jhaas over 16 years ago in reply to ASano
    while it is probably way too late, you may want to check out the following link: http://ow.ly/2OgFh (plastic) or in steel http://ow.ly/2OgJW
  • Catwell
    0 Catwell over 16 years ago in reply to jhaas
    Josiah,
    Great product link. That Bud enclosure is what I am using now, but your link is the cheapest I've ever seen.
    Thank you very much.
    Bud NBB-22245Bud NBB-22245
    Cabe
  • Catwell
    Josiah,
    I also need the backplate for that cabinet. Can you find the part number for me? I am having a hard time finding it.
    A metal backplate would be prefered.
    Thank you.
    Cabe
  • jhaas
    0 jhaas over 16 years ago in reply to Catwell
    Not an issue at all.  The Bud part number is NBX10986.  You can find it at the following link:
    http://www.newark.com/bud-industries/nbx-10986/enclosure-panel/dp/83F5565
    If you decide you want it in plastic as opposed to the 16ga Steel panel, just add an "PL" to the end of it (NBX10986PL)
    Hope this helps.
    Josiah
  • Catwell
    Josiah,
    Way to come through on the enclosure. I am going to go with your suggestion. And I'm going to try the plastic back plate. I'm not sure how I am going to ground the entire system that way. Normally I place the AC ground on the backplate.
    Thanks again.
    Cabe
