Robotics
Robotics
Forum What determines a wires current carrying capacity rating?
  • Answers 2 answers
  • Subscribers 77 subscribers
  • Views 916 views
Malcolm
Malcolm over 16 years ago
Easy question? I'm interested in what comes back as I have found it's not as simple as it seems. Suggest away friends
  • WarrenW
    0 WarrenW over 16 years ago
    Ok, this has lots of factors.
    1. Cross sectional area
    2. Frequency of the signal (the higher the frequency the less effective cross sectional area)
    3. Proximity of other cables or materials that may be inductive
    4. Is it buried in the ground?
    5. Environmental issues like temperature
    6. Allowable voltage drop
    and the list goes on.
    There are some calculators available to allow a lot of these to be taken into account for typical mains power applications.
    http://www.cablecalc.com/cable.htm is one
    Cheers
    Warren
  • Malcolm
    0 Malcolm over 16 years ago in reply to WarrenW
    Thanks Warren for the reply, certainly some criteria I hadn't thought of. How does a manufacturer specify the current rating of a cable they have manufactured? The reason I ask is that there seems to be a very wide different current rating for similar single cables with the same cross sectional area (some 18amp some 10amp). In fact I think I will post that as a question. Thanks again Warren If anyone can add to the list Warren has provided I would be grateful
  • WarrenW
    0 WarrenW over 16 years ago in reply to Malcolm
    Here is a link to a free cable calculator based upon New Zealand wiring regs.
    http://www.generalcable.co.nz/newzealand/NZDownloads/Gencalc.aspx#download
    enjoy.
    Cheers
    Warren.
    0 e14 Contributor over 16 years ago in reply to Malcolm
    I have found it is usually because the higher rated cable the manufacturer thinks it is OK to let it get hotter.
  • Malcolm
    0 Malcolm over 16 years ago in reply to e14 Contributor
    Thanks Rich and Warren for your replys. I have posted another question similar to this but relating to how a manufacturer determines the current rating of a cable they manufacture. Please have a look at http://www.element-14.com/community/message/7800#7800 Thanks again, regards Malcolm
