Robotics
Robotics
Forum Servo trouble
  • Replies 52 replies
  • Subscribers 65 subscribers
  • Views 5298 views
Servo trouble
royston02
royston02 over 11 years ago
I wanted to know if a servo left without power in stationery mode (without making me want to turn it) lift the weight?
Eg:- A skateboard. I just want to stand on itwithout it moving. the skateboard is the servo. Will the skateboard i.e servo stand or fall? No battery.
    dougw over 11 years ago +2
    If you can live with a normal DC motor and use it with a worm gear, it should "lock" when not powered.
    mcb1 over 11 years ago in reply to royston02 +1
    Try this .. Open your browse and enter this in a google search "how does a servo work" the first two results give a good breakdown of how it works. Mark
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    Note there are many different systems that fall under the name of SERVO. The one you linked in may be geared but not like the one shown above. A typical Remote control plane/Car/Boat servo is based on…
  • dragonstyne
    0 dragonstyne over 11 years ago in reply to royston02
    Greetings  Royston,
    Peter is right,  your description sounds like you want to build a device any that can carry weight  without the device  feeling  the weight.
    It's like being able to carry an African elephant  on a small car.  The only way to make  the car not feel the weight of the elephant  is to suspend  the elephant  with another  device.
    Or maybe  design an anti gravity  device.  Regardless, a servo will not do this.
    -Steve
  • royston02
    0 royston02 over 11 years ago in reply to dragonstyne
    The quad copter's an example, not a real idea. I want to carry the weight on this-http://img.deusm.com/eetimes/2013/10/1319757/max-0087-03.jpg
    Secondly, the quadcpoter's an examle, all I want to know is will the quad hold the airsoft with the servo as the medium and putting the weight of only the servo and not the weight of the servo and the gun.
  • dragonstyne
    The servo alone will not hold the weight stationary. You would need something else to support the weight when the servo is not powered.
    -Steveimage
    0 dougw over 11 years ago in reply to royston02
    My best guess as to the geometry you are trying to describe is like this image:
    1) The entire weight of the load and platform rest on the servo.
    2) The entire weight of the servo plus platform plus load rest on the vehicle.
    3) The entire weight of the vehicle plus servo plus platform plus load rest on the ground.
    It does not matter whether the servo is burning power to hold position or held in position by friction in the gears, the weight on the vehicle is the same. (according to Isaac Newton)
  • royston02
    0 royston02 over 11 years ago in reply to dougw
    You are the first one to get it right.
    Wong, according to me, the weight applied on a servo is absorbed by the gear and no weight is put on the frame( that is what I learnt)
    however, is there something else that can replace it(like a spring or shock absorber) that can replce the serco and be used in such a way that it dosen't put any weight on the frame?
    0 Robert Peter Oakes over 11 years ago in reply to royston02
    given the above picture and your response, I get the impression that you think Doug has solved your problem, it has not. Doug was trying to demonstrate to you that it is not possible to increase the LOAD and not add weight to the vehicle (AKA FRAME)
    Any additional weight is transferred through all the other parts and will still end up on the vehicle. Changing the servo to springs or other components may reduce cost and make the design simpler but wont change the laws of physics
    As an example
    Get a kitchen scale (Or a Bathroom one for that matter)
    add a plate to the kitchen scale, it will indicate e weight. Correct ???, if your doing the bathroom version, then it shows your weight
    now add a bag of something to the plate, even though the bag is not on the scale, it is technically on the plate, the scale still registers its weight in addition to the plate
    if your standing on a scale, pick up a heavy object, did the scale change its reading... of course it does. It does not matter if you hold the weight, or put it in a back pack, it will still register on the scale
    This is what we are all trying to explain to you ?
    I hope this example has you understanding why your not getting the answer you desire, perhaps the question is wrong but only you know that.
    Peter
  • royston02
    0 royston02 over 11 years ago in reply to Robert Peter Oakes
    What about electromagnets? They can be set in such a way that they won't fly of while repelling and won't register the weight on a kitchen scale?
    Yes they will image
  • royston02
    Well then, that's my cunclusion. Thanks for helping out.
    Yes they will, as in YES THEY WILL REGISTER THE WEIGHT OF THE LOAD AND TRANSFER IT TOO THE CAR
    It does not matter how you carry the load on the car or how you decouple it from physically touching the chassis ,  the car will always feel the weight, short of putting it on a trailer or using a separate powered carrier to hold it and follow the car
    If the electro magnets where sitting on the counter, not on the scale then the load could "Hover" over the scale and it would not be felt, but you wont be able to move the scale / Car
