Robotics
Robotics
Forum Servo trouble
  • Replies 52 replies
  • Subscribers 67 subscribers
  • Views 6870 views
Servo trouble
royston02
royston02 over 11 years ago
I wanted to know if a servo left without power in stationery mode (without making me want to turn it) lift the weight?
Eg:- A skateboard. I just want to stand on itwithout it moving. the skateboard is the servo. Will the skateboard i.e servo stand or fall? No battery.
    dougw over 11 years ago +2
    If you can live with a normal DC motor and use it with a worm gear, it should "lock" when not powered.
    mcb1 over 11 years ago in reply to royston02 +1
    Try this .. Open your browse and enter this in a google search "how does a servo work" the first two results give a good breakdown of how it works. Mark
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    Note there are many different systems that fall under the name of SERVO. The one you linked in may be geared but not like the one shown above. A typical Remote control plane/Car/Boat servo is based on…
  • dragonstyne
    0 dragonstyne over 11 years ago in reply to royston02
    Greetings,
    do you have a drawing the the load plate removed showing how the servo is connected to the vehicle.  That would help. The way servos are designed , I don't see it holding the load plate stationary without help such as a transmission or a support that can be moved out of the way when the load is to be moved.
    -Steve
    0 dougw over 11 years ago in reply to royston02
    You are correct, I am a long way from understanding why this servo is needed - it sounds like there is no motion.
    Any load on the servo horn will be transferred through the motor mounts to the frame, whether it is moving or not.
    If the servo never needs to move, why use a servo at all? Why not just a fixed bracket?
    If the servo is being used as a shock absorber, it will require movement - the restoring/holding force could be provided by power to the motor or a simple spring.
  • dragonstyne
    0 dragonstyne over 11 years ago in reply to dougw
    I agree Douglas,
    It sounds like he's using the servo as an expense hinge or shock absorber.
    -Steve
  • dragonstyne
    Or like you say, a mounting device.
    -Steve
  • royston02
    0 royston02 over 11 years ago in reply to dragonstyne
    Not like a cheap mounting bracket/shock absorber. My plan is to mount a servo horn on the servo and the servo horn to the top load. I learnt that all the weight that is put on the servo is absorbed by the gears. So my plan is to use a medium between the top and bottom frame without transferring the weight of the top frame to the bottom. I thought of using a servo as the medium.
    You all are talking about it as an expense hinge or shock absorber. I wanted to use the servo to absorb all the weight by the gears and not put any force on the motors. Also, can a shock absorber be used as a medium between the top and bottom frame without transferring the weight of the top frame to the bottom.Also if a shock absorber can be used, how much weight can it carry?
  • dragonstyne
    Is the servo going to be powered at any time to move anything?
    -Steve
    0 Robert Peter Oakes over 11 years ago in reply to royston02
    I am not sure if I am understanding you correctly but you cant have a frame carrying another frame, carrying a load and not have the weight be transferred all the way down though the frames to the ground the wheels are touching (Unless you have invented Anti Gravity, in which case I will be suitably impressed)
    You can use shock absorbers (Active or passive) to absorb inertial shock either from  a rough terrain while moving or from a change in the load say dues to extra load being added, but this is absorbing the shock and vidration, not eliminating the weight from being transferred to the ground through all the parts between the load and the ground
    So if your going to program a controller to manage a servo in an attempt to function as a shock absorber, well then please say so, if not then im not sure what your trying to achieve as your description appears to defy gravity and other laws of physics
    This is why we are repeatedly asking you to provide a sketch of the complete frames how there all connected and how the servo plays a part in all of it (Or how you plan for it to play a part)
    Sorry but im just not getting what your trying to achieve, my colleagues on the forum have been trying to wean this additional information from you but so far it is still rather vague, sorry ?
  • royston02
    0 royston02 over 11 years ago in reply to Robert Peter Oakes
    I'll try to explain my objective in a different manner.
    Let's say I have a quadrotor. I want to mount an airsoft gun to it. I want the gun to be mounted in such a way that it dosen't put weight on the quadrotor. So which is the best way to do it? First thoughts are servo's. But I don't want the servos to consume power. So will the servo hold the airsoft on my quadrotor without putting the weight ok the servo?
  • royston02
    0 royston02 over 11 years ago in reply to royston02
    As per the picture, I don't have a frame.
    by definition of what your describing, it cant be done
    if you have a quad-copter and add anything to the device such that it will "Fly with it" then the weight of that attached object MUST be carried by the Quad-copter,
    it does not matter how you attach the object (Suspend underneath, sit on top, other options), it will always add weight to the flight frame if the frame is to carry the object with it in flight
    the only way you could do this without adding weight to the quad copter is to make the airsoft have its own flight mechanism and have it fly in perfect synchronization with the quad-copter , but then you just put the load onto another air frame instead.
    Sorry to sound like a downer but maybe im not getting what you need from your description
    Peter
