Robotics
Robotics
Forum Cable for pipe and trenches robot.
  • Subscribers 77 subscribers
  • Views 679 views
joey1988
joey1988 over 9 years ago
Hello. I am currently working on a project that requires making a robot crawler capable of going through mud, sand, demolition debris, pipes for inspecting certain sections of building and installations sites. Is there a certain cable that can be used for both, powering the rover as well as steering and recording ? Or I will have to use two separate sets of cables and design some sheathing system that will keep them together ? The components that will be used are 9v 1 dc motor, 1 5v polarity switch, 1  and a microcamera.
  • kas.lewis
    kas.lewis over 9 years ago +2
    Just read about the links below, probably not what you are looking for but worth the posting nonetheless. Kas DirtyPCBs.com DIRTY CABLES: Cheap custom cables available now « Dangerous Prototypes
  • Workshopshed
    Workshopshed over 9 years ago +1
    Custom cables from Dirty Cables sound good but there are some off the shelf ones available. I googled "Power and signal cable" and found these https://www.ltt-versand.de/en/Sound/Cables-and-connectors…
  • kas.lewis
    Kas
    DirtyPCBs.com
  • Workshopshed
    I googled "Power and signal cable" and found these https://www.ltt-versand.de/en/Sound/Cables-and-connectors/Not-assembled-cables/Audio-electricity-and-hybrid-cables-9_404…
    So something like that might work.
