Sensors
Sensors
Sensor Forum Connection of Piezo Film Sensor
  • Subscribers 350 subscribers
  • Views 1328 views
Hi,http://uk.farnell.com/prowave/fs-2513p/sensor-piezo-film/dp/1007374#similarProducts?COM=Experts
FS-2513P - PROWAVE - SENSOR, PIEZO FILM | Farnell element14
This Piezo Film Sensor has positive and negative terminals?
  • michaelwylie
    michaelwylie over 10 years ago +1
    Check the datasheet. You'll see their driving circuit where they are tying one pin to ground. In the case of a piezo I don't think it's necessary to ground one of the terminals, you could read it differential…
    e14 Contributor over 10 years ago in reply to shabaz +1
    Thanks shabaz.
  • michaelwylie
    Check the datasheet. You'll see their driving circuit where they are tying one pin to ground. In the case of a piezo I don't think it's necessary to ground one of the terminals, you could read it differential if you want. Practically you will probably ground one of the terminals though.
    shabaz over 10 years ago
    Hi Ng,
    Some information on how to use these is here:
    Impact, Vibration and Ultrasound Sensing with PVDF Piezo Sensors
    Hi shabaz,
    I am planning to use PVDF film to measure the vibration (signal) due to the different type object's surface. Is PVDF film produce the charge when the force applies to the  surface of PVDF film?
    Thank you.
    shabaz over 10 years ago in reply to e14 Contributor
    Hi Ng,
    Absolutely, this is a very good use-case for PVDF. I tried this too, to be able to identify the start position of paper stickers on a strip of peelable tape, and it was picking up vibrations from the rough surface of the paper : )
    I believe (not tried it) that it could identify different objects due to the surface roughness, with some processing of the data.
    I just used a strip of metal attached to act like a stylus (a bit like a record player) but flattened. You can see it in the URL mentioned earlier. Depending on your actual scenario, perhaps you may want to try different materials as a stylus, maybe even exotic things like sapphire or diamond, and some controlled way of moving it or the object, e.g. with a motor. If you're using a motor, you'll probably want something
    high-end to get the smooth motion, or consult with some mechanical engineer since this could be an advanced topic in itself.
    Thanks shabaz.
