Sensors
Sensors
Sensor Forum Make a sensor at home
  • Replies 7 replies
  • Subscribers 352 subscribers
  • Views 1372 views
  • industrially
  • make
  • diy
  • sensor
  Please i am asking if there is a way that a sensor could be made at home that is DIY sensor or can they be only manufactured industrially
  • billpenner
    billpenner over 13 years ago
    It depends on the type sensor. Probably most sensors would be better purchased.However for education and self satisfaction some can be built but precision, calibration, cost,etc.would be factors. do you have a specific sensor in mind?
    Bill
    DAB over 13 years ago
    Hi Yacham,
    If you can provide us with some information on what kinds of information you want to sense, then we could possibly provide you with ideas on how you might make a sensor for those events.
    You need to help us help you.
  • davewr
    davewr over 13 years ago
    There are all sorts of projects that involve wire coils and a bit of circuitry. For example -- a fluxgate magnetometer:
    http://motivationtolearn.org/wordpress/?p=1347
    Yeah -- I know it's a kids site -- but I bet it works.
    Circuit Cellar had a Proton Magnetometer design -- I have the Issue -- May 20xx  something or other. Very sensitive and suitable for mineral exploration work even.
    There are lots of projects with reed switches (magnetic) and wire coils for proximity -- and limit switches.
    Float switches and circuits for tank levels, overflow and sump pump.
    The manufacturing process is about making a consistent product.
    Most work today for embedded engineers is in commercial use/programming of the refined designs of these products.
    For this one -- the search engines are your friend.
    e14 Contributor over 13 years ago in reply to davewr
    i was thinking of a DIY distance or temprature sensor. I  want to do it for the sake of self satisfaction .
  • davewr
    davewr over 13 years ago in reply to e14 Contributor
    What do you mean by DIY -- are you prepared to mine and refine and cut your own crystals for example?
    http://en.wikipedia.org/wiki/Piezoelectric_sensor
    Find a crystal -- hook up some leads -- freezing water, boiling water -- calibrate them yourself, correct for altitude though.
  • jaytech101
    jaytech101 over 13 years ago in reply to davewr
    I would love to create my own sensors too I would love to see be done.
    e14 Contributor over 12 years ago in reply to jaytech101
    Maybe I'm a bit late... but..   we've created a site describing how to create your own wireless sensors and actuators.
    You'll find build instructions here:  http://www.mysensors.org
    All libraries used is open source.
