Sensors
Sensors
Sensor Forum Speed Sensor
  • Subscribers 350 subscribers
  • Views 809 views
Speed Sensor
hayhaystyle
hayhaystyle over 12 years ago
What is the best type of speed sensor for geared motors application?
  • D_Hersey
    D_Hersey over 12 years ago +1
    This is a situational question. But under the presumption that you are in a somewhat dirty environment, depending upon your resolution requirements, how versed in electronics you are, I'd say a saturating…
    dougw over 12 years ago +1
    Typically a magnetic pickup sensor is used unless you need very low speed operation. I have no idea why they are so expensive since they are made from a coil of wire and a magnet. Speed Sensors Product…
  • D_Hersey
    This is a situational question.  But under the presumption that you are in a somewhat dirty environment, depending upon your resolution requirements, how versed in electronics you are, I'd say a saturating Hall-effect sensor might be the ticket for you.
    Speed Sensors Product List | Sensors & Transducers | Newark element14 Canada
    Hall effect speed sensors can measure down to zero speed and the output needs less signal conditioning.
    Mercedes C220 C230 C280 Right Front ABS Wheel Speed Sensor Bosch Hall Effect | eBay
    Alternatively, you might use an optical encoder wheel if the environment is clean.
  • D_Hersey
    Peruse these to get up to speed on common methods:
    http://www.allegromicro.com/SearchResults.aspx?q=application+note&x=0&y=0
  • billpenner
    billpenner over 12 years ago
    Could you be a little more specific about the application?  Do you want to measure the speed of a gear? A Hall sensor and magnet package would be indicated.
