Sensors
Sensors
Sensor Forum Height sensor
  • Subscribers 351 subscribers
  • Views 809 views
Height sensor
Hi
actually i want to sense the height of suspension car model after i pull it up and down continuously using cylinder and air pressure...which type of height sensor(position sensor) is recommended for such operation ....?
    dougw over 12 years ago +1
    There are lots of great linear position sensing technologies for harsh environments such the LVDT mentioned above. Others include Positek inductive position, Honeywell Smart magnetoresistive, Micro-epsilon…
  • ravi_butani
    ravi_butani over 12 years ago
    If you put some details that what is range you are looking for and rough image of structure you are designing then some one can answer more precisely... As of your question I unserstand, I suggest you to use LVDT sensor actually used to detect displacement.
    There are lots of great linear position sensing technologies for harsh environments such the LVDT mentioned above. Others include Positek inductive position, Honeywell Smart magnetoresistive, Micro-epsilon magneto-inductive, Penny&Giles contactless linear, SenseAble magnetostrictive, etc. However these are all pretty expensive. There are many others thjat are lower cost, but require some mechanism to adapt to this application such as Hall effect, optical encoders, ultrasonics. etc. One low cost sensor you might be able to use is an optical proximity sensor such as a Sharp GP2Y0A02YK0F.
  • vsluiter
    vsluiter over 12 years ago
    And here's   a very low cost string potentiometer. Not suited for rough environments:
    https://www.youtube.com/watch?v=rGB2NAki0PI
    https://www.youtube.com/watch?v=GnQHJV7R4UI
    thanks all of you
