Sensors
Sensors
Sensor Forum Anyone know a good sensor manufacturer?
  • Subscribers 350 subscribers
  • Views 761 views
  • sensors
Hi!
I'm looking for a custom sensor manufacturer. I want something made that looks and acts similar to a pressure sheet but i want it to respond when a secondary object comes within a certain distance. Thank you new friends!
    michaelkellett over 11 years ago +2
    You aren't going to buy this off the shelf. Why not use a standard pressure pad sensor an a separate proximity sensor. What are you trying to do - how accurately are you trying to estimate the position…
  • amgalbu
    amgalbu over 11 years ago +1
    Hello I don't know your application requirements but you can have a look at this sensor http://www.silabs.com/support/training/Pages/infrared-multi-function-board-demo.aspx I tried it and it's very works…
    You aren't going to buy this off the shelf. Why not use a standard pressure pad sensor an a separate proximity sensor. What are you trying to do  - how accurately are you trying to estimate the position of the "secondary object" and what is it ? How many of these devices do you need.
    (BTW there are no sensor manufacturers who make everything - you need to find the right one for the kind of sensor you need.)
  • amgalbu
    Hello
    I tried it and it's very works very fine!
    e14 Contributor over 11 years ago in reply to michaelkellett
    The secondary object needs to get a response at about 2 - 4 inches. Then activate an LED. Power source could be disposable or rechargeable. An extremely crude example would be a laser tag vest. It has the sensors then lights up when contacted by a laser. Instead of a laser, this would activate within a close proximity to an object. Thank you so much!!
