Sensors
Sensors
Sensor Forum Which Thermister???
  • Replies 7 replies
  • Subscribers 351 subscribers
  • Views 1866 views
Which Thermister???
oldokie
oldokie over 10 years ago
If this thermister  RL2004-582-97-D1RL2004-582-97-D1 NTC THERMISTOR ) is not recommended for immersion in gasoline or diesel
can you suggest a substitute that will work as a sensor for a low fuel light. I am fairly certain that these thermisters
are being used in fuel tanks. I am a novice when it comes to electronic subjects, detailed answers, please.
Thanks...
Old Okie
    0 jw0752 over 10 years ago
    Hi Gerald,
    I do not pretend to know very much about fuel tank sensors but I am having trouble imagining how a thermistor could be used as a low level sensor. For example in most situations the fuel and the air above it will have the same temperature. I am interested in your question though and if thermistors are actually used in this application it would be nice to learn the physics involved.
  • D_Hersey
    0 D_Hersey over 10 years ago in reply to jw0752
    Thermistors are non-linear, I think their transfer fn is a fairly high-order poly.  If the sensor is to detect the binary low-fuel condition, if a little electrical energy is input, and it is in air it will self-heat into a certain regime.  If it is immersed, it will stay cool
    0 jw0752 over 10 years ago in reply to D_Hersey
    Hi Don,
    Yes I can see that this could be done. Do you know if this is an actual technique?
  • D_Hersey
    http://www.ti.com/lit/ds/snis160e/snis160e.pdf  (fig 32)
    You should know better than to ask me about the nature of reality at this hour by now, John
    I know that it is useful in liquid chromatography, but IDK about bulk quantities of fuel.  I do think that's how they do it, even in airplanes.  Probably the trick is to scrupulously avoid the flash point.
    Does our hero have the repair literature for his gadget?
    Hi Gerald,
    Sorry if we haven't been exactly on subject. I know that regular epoxy is impervious to gasoline. I once patched a puncture in the gas tank of my 1967 Plymouth Fury III with regular mix epoxy and it held without problem for the 5 or 6 years that I drove the car. If you feel the above mentioned Thermistors will not handle gasoline perhaps you can put a coating of epoxy on them. Personally I would probably go with original parts if I was dealing with a fuel tank sensor. No sense putting yourself in any danger if there is a malfunction and a potential spark.
  • D_Hersey
    Level Sensing: Analog Dialogue: Analog Devices
    you can just google 'thermistor' and 'fuel'
    Classically, the circuit was the battery, a light bulb and an NTC thermistor in series
  • oldokie
    0 oldokie over 10 years ago
    I realize that this is a simple question for experienced electronics people but it was a puzzle to me.
    The discussion has been enlightening and informative. I have found the correct thermister for this system.
    The simple answer is that the thermister serves as the ground leg for the light and little if any current is
    present in the fuel tank.  Thanks for the help.
    Old Okie/Gerald  McGarvin
