Sensors
Sensors
Sensor Forum Accurate distance sensor ... low power
  • Answers 2 answers
  • Subscribers 350 subscribers
  • Views 1287 views
f_jones
f_jones over 8 years ago
Any thoughts on this ... I'm trying to find a sensor to work with an Arduino  (or similar) Micro-controller.  The sensor needs to measure the distance to 500microns over a range of 50mm. Ideally measurements would be made at a >500Hz and the power consumption would need to minimal (or minimised).  best I can find so far are all at 10-30V range with power consumption of about 0.5Watts.
Mar
    dougw over 8 years ago +1 suggested
    http://www.st.com/content/ccc/resource/technical/document/datasheet/c4/11/28/86/e6/26/44/b3/DM00112632.pdf/files/DM00112… http://canada.newark.com/stmicroelectronics/vl6180xv0nr-1/proximity-sensor-lga…
  • f_jones
    f_jones over 8 years ago in reply to dougw +1
    Thank you, good suggestion but I think the accuracy quoted is 2mm - am I misreading the data sheet? I'd be happy to receive other suggestions. Mark
    0 dougw over 8 years ago
    http://canada.newark.com/stmicroelectronics/vl6180xv0nr-1/proximity-sensor-lga-12-20-c-70/dp/46Y8576?st=VL6180X
  • f_jones
    0 f_jones over 8 years ago in reply to dougw
    0 DAB over 8 years ago
    Hi Mark,
    Take a look at the TI capacitive sense board.
    I think it can give you both the range of distance and the accuracy.
