Sensors
Sensors
Sensor Forum Dark detecting circuit
  • Subscribers 350 subscribers
  • Views 1619 views
  • dark detecting
  • ldr
yagmurozdemir
yagmurozdemir over 6 years ago
I had tried dark detecting circuit (3 volt battery,1 kohm resistance and 10 kohm resistance, LDR,Npn transistor) but by bonding with parallel (but)red leds but my circuit lights on in sunlight and lights on in the dark??! And when I covered Ldr sensor with my hand, I saw that there was still nothing new. I calculated inner resistance and found out the inner resistance is (approximately) 100 ohm. And first of all, I tried the same thing with one, and then two green leds with parallel bonding and I found out the inner resistance (with 1 green) is 80 ohm and 190 ohm ( with 2 parallel green led). After I used this circuit 500 ohm resistance but there was nothing new, again. The one below is what I have been talking about. I did not understand what is wrong with mine. Please help me. I am wondering what you will say.
Thank you.
Yagmur
  • aswinvenu
    aswinvenu over 6 years ago +4 verified
    Hi your circuit is not working because you are always driving a current through the LEDs from the power supply. So the LEDs remains on. Please try the following circuit instead. By keeping the R1 variable…
  • yagmurozdemir
    yagmurozdemir over 6 years ago in reply to aswinvenu +1 suggested
    Hello I am sorry for my late response because i was dealing with some health issues. I had tried this circuit and it is working! Thank you so much. Kindly regards Yağmur
  • aswinvenu
    0 aswinvenu over 6 years ago
    By keeping the R1 variable you can control the threshold value for turning the LEDs on.
    Aswin
  • yagmurozdemir
    0 yagmurozdemir over 6 years ago in reply to aswinvenu
    Hello
    I am sorry for my late response because i was dealing with some health issues. I had tried this circuit and it is working! image
    Thank you so much.
    Kindly regards
    Yağmur
