Sensors
Sensors
Sensor Forum Can an Acceleration Sensor (MEMs) Measure Velocity and Distance?
  • Subscribers 349 subscribers
  • Views 357 views
  • acceleration_sensor;mems;led_lighting
Oliver
Oliver over 16 years ago
Hello:
I want to DIY a solution by using a MEMs acceleration sensor to measure velocity of the swing of human's arm.
How is the value of acceleration converted into velocity? and how do i reduce the error if i use integral method?
Any suggestion and idea will be appraciated.
best regards;
oliver zhang
    0 e14 Contributor over 15 years ago
    Hi Oliver,
    the straightforward method is to integrate the signal along time. But be careful with the offset, you should need to use some kind of filter...
