Sensors
Sensors
Sensor Forum Kalman Filtering
  • Subscribers 351 subscribers
  • Views 884 views
  • detector
  • robotics
Kalman Filtering
gtrplyer16
gtrplyer16 over 11 years ago
All,
     So last semester in college I created a GoPro mount that was mounted to a servo with a gyro on it to be mounted on RC cars that tilts the camera angle up or down based on if you are on a hill or not. I turned the project in and the professor suggested using Kalman Filtering to take instability out of the gyro and make it more stable. I did some research but I can not seem to find any helpful resources online for how to go about programming the filter. I was hoping someone would be able to give me some advice on how I can do this. I am using a Basic Stamp 2 for reading the gyro and controlling the servo. Am I able to use this same stamp for the filter or would I need a different chip and/or programming language. Any help  would be greatly appreciated. I am not sure if this was the appropriate place to post this question.
  • clem57
    0 clem57 over 11 years ago
    gtrplyer16
       I found a paper done in academics that gives a snippet of the code. Read and see http://academic.csuohio.edu/simond/courses/eec644/kalman.pdf
    Clem
  • vsluiter
    0 vsluiter over 11 years ago
    Hi Tyler,
    Just a curious question:
    Kalman uses multiple sources of information to minimize noise; if you only have a gyro, what use does it have?
  • gtrplyer16
    0 gtrplyer16 over 11 years ago in reply to vsluiter
    It has no use. The professor suggested that but apparently was going in the wrong direction with it.
  • vsluiter
    0 vsluiter over 11 years ago in reply to gtrplyer16
    If you add an accelerometer you can use that for stabilization, and use a Kalman filter to combine those two sources.
