Sensors
Sensors
Sensor Forum While training the neural network I am getting the following error
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 347 subscribers
  • Views 1533 views
  • vision
manojroy123
manojroy123 over 2 years ago
While training the network using the given command I am getting error in command prompt.
python train.py --img 640 --epochs 3 --data ..\datasets\dataset.yaml --weights yolov5s.pt
above is the command given
  • battlecoder
    battlecoder over 2 years ago in reply to javagoza +3 suggested
    If the problem is in "line 7, column 1" I think the issue is the hierarchy. Line 7 is where the nested elements (head, helmet, person) start. Check that you are not using tabs to indent those attributes…
  • javagoza
    javagoza over 2 years ago +1
    I think the error message indicates a syntax issue while parsing a YAML file. Specifically, it's complaining about a missing colon (": ") after a simple key. This suggests that a key-value pair is not…
  • javagoza
    javagoza over 2 years ago in reply to manojroy123 +1 suggested
    snc or nc? Try # Parameters nc: 3 # number of classes
  • javagoza
    0 javagoza over 2 years ago
    I think the error message indicates a syntax issue while parsing a YAML file. Specifically, it's complaining about a missing colon (": ") after a simple key. This suggests that a key-value pair is not formatted correctly.
    Carefully check the line where the error is occurring. Look for missing colons or incorrect indentation. Mappings use a colon and space (“: ”) to mark each key/value pair. Don't forget the space.
    YAML Ain’t Markup Language (YAMLTm) revision 1.2.2
  • manojroy123
    0 manojroy123 over 2 years ago in reply to javagoza
    I am using Win8.1 os where is the error.
  • javagoza
    0 javagoza over 2 years ago in reply to manojroy123
    snc or nc?
    Try
    # Parameters
  • battlecoder
    0 battlecoder over 2 years ago in reply to javagoza
    Check that you are not using tabs to indent those attributes. As per YAMLs specifications:
    "To maintain portability, tab characters must not be used in indentation, since different systems treat tabs differently"
  • manojroy123
    0 manojroy123 over 2 years ago in reply to battlecoder
    'name:' had space after it for which it was not working
  • manojroy123
  • manojroy123
