Sensors
Sensors
Sensor Forum What parameters do we need to predict & detect imminent danger caused by a charging battery?
  • Replies 31 replies
  • Subscribers 347 subscribers
  • Views 5330 views
HKPhysicist
HKPhysicist over 1 year ago
Dear Engineers,
Every month or year, charging batteries cost human lives and total household destruction.
I have successfully developed a Flame Detector which sends alert to internet broker over a wifi router once it detects "flame" near a charging battery.
Then, I want to improve it and add some more parameters to predict & detect imminent danger caused by a charging battery.
What suggestions could you make to improve my flame detector design?  Thanks for your comments.  Upside down
    dougw over 1 year ago +4
    I think your temperature senor is a good early warning method. Other types of sensor to consider would be: leakage of electrolyte swelling of the battery outgassing physical damage such as…
  • battlecoder
    battlecoder over 1 year ago +2
    If you have data of batteries that have failed, and the conditions under which they did, you could create a small predictive model. Three failure modes that are common are batteries being exposure to high…
  • anniel747
    anniel747 over 1 year ago in reply to HKPhysicist +1
    Chemistry of the batteries to monitor?
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to shabaz
    Everybody assumes battery charging works as design and users use it wisely.
    and I assume misusing, low quality parts, accidents, etc. Thinking
    0 shabaz over 1 year ago in reply to HKPhysicist
    Yes but for what scenario? People charging mobile phones? Or scooter batteries, or laptops, tablets etc?
    Is it like a fire alarm, but pointed at only one device at a time?
  • HKPhysicist
    So I am thinking to add more sensor parameters to my apparatus, such as even more flame detectors. Slight smile
  • anniel747
    0 anniel747 over 1 year ago in reply to HKPhysicist
    HKPhysicist said:
    but they can still be overcharged and exploded, very often.
    You are talking about fakes? Do you have exemples?
  • anniel747
    All BMS I saw take care to prevent accidents but bypassing safety features is always a possibility.
  • HKPhysicist
    Another house in Australia has gone completely with human life lost owing to charging scooters.
    Early warning should be a good business.Money mouth
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to anniel747
    Big brand name, for example, Samsung, also explodes! Laughing
    For a certain period of time, they could not be brought along into an aeroplane.
    Have you ever ordered battery through postage?  Mailing any type of battery is refused through air courier.
  • anniel747
    Again all traceable to fakes.
    0 Jan Cumps over 1 year ago in reply to HKPhysicist
    maybe add a feature that allows alerts when internet  connection is down, or when the broker is down?
  • battlecoder
    0 battlecoder over 1 year ago
    If you have data of batteries that have failed, and the conditions under which they did, you could create a small predictive model. Three failure modes that are common are batteries being exposure to high temperatures, physical damage / punctures, and excess current consumption (for example through a short circuit).
    There's actually an Open Data Set with such experiments, available for free:
    Described here: https://www.sciencedirect.com/science/article/pii/S0378775324000570#da0010
    Available to download here: https://www.nrel.gov/transportation/battery-failure.html
    Now, the dataset gets really technical with their measurements, some of which you can't really replicate without very specialized equipment, but it should have some temperature readings associated to even their short circuit tests, and you could use that. If you can measure the discharge rate and temperature you are probably half way there.
    Also based on that dataset; if you can measure the "mass" of the battery you could detect if it's losing mass in any way (i.e: it's leaking or venting), but I assume you would require an extremely accurate sensor for that.
    Another idea: If you are working with Li-Po batteries, an additional sensor you could have is one of those flexing/strain sensors placed length-wise to detect swelling.
