Sensors
Sensors
Sensor Forum Is there a way to measure density of liquid electronically without using tilt sensor as they are typically not that reliable ?
  • Replies 7 replies
  • Subscribers 345 subscribers
  • Views 1208 views
  • density
manojroy123
manojroy123 over 1 year ago
Is there a way to measure density of liquid electronically without using tilt sensor.
    Jan Cumps over 1 year ago
    Can you give some context? Maybe a scenario of what you want to measure, and what you aren't looking for?  And why to not consider "tilt sensor"?
  • manojroy123
    manojroy123 over 1 year ago in reply to Jan Cumps
    I want to measure electrolyte solution for electroplating like copper sulphate.
  • dang74
    dang74 over 1 year ago
    Digital hydrometer perphaps?
    dougw over 1 year ago
    It may be a bit cumbersome, but you could try deducing density from measurements of volume and mass.
  • SensoredHacker0
    SensoredHacker0 over 1 year ago in reply to manojroy123
    sounds like youre attempting to assert composition of a solution based on buoyancy.  its not the worst plan ever, but your hydrometer isn't going to have the same precision as an instrument designed to give you compositional analysis. in a sealed vessle you could use differential pressure monitoring to get a level, or ultrasonic detection tuned to the vapor composition (sound waves through vapor) to derive density princely the same as an acoustical wave sensors. you could shine a laser through your vessel or a glass tube then use the fluid's refractive index. The refractive index, which is related to a substance's optical density, can then be used to calculate the physical mass density.
    ** lots of assertions in these sorts of assessments, that one is measuring a specific thing, and not something functionally similar.  personally for the application I'd think your be more interested in specific gravity.
  • SensoredHacker0
    ever wonder if toy could speed run electroplating by using a super critical vapor?
    think higher pressure,  greater energy transfer, and less wasted solution
  • manojroy123
    manojroy123 over 1 year ago in reply to SensoredHacker0
    Can specific gravity be used to test density of the electroplating solution while the electroplating process is active.
