Sensors
Sensors
Sensor Forum CO2 sensor recommendation
  • Replies 21 replies
  • Subscribers 354 subscribers
  • Views 8761 views
  • gas sensor
  • co2 sensor
koudelad
koudelad over 9 years ago
I'd like to ask you for a CO2 sensor recommendation. My goal is to measure an air quality indoors (at home, office...) and take this as one of factors to control a ventilation. It is a hobby project to be installed at my home.
So far, I've found quite famous MQ-XX sensors, using various metal compounds. They are cheap (ca. €4), but need to be calibrated. Then I found quite a few Amphenol sensors, using IR light, priced ca. €150 - €350.
There are also volatile organic compounds (VOC) sensors, which provide output that correlates with CO2 level.
My requirements are: package solder-able at home (or a ready made module with a connector), some common interface (I2C for example), no need to calibrate the sensor.
Did you use any of the mentioned above in your projects?
Thank you, David
    michaelkellett over 6 years ago in reply to shabaz +4
    Hi Shabaz, Your table is a bit old - the current atmospheric base level is 406ppm: https://www.co2.earth/daily-co2 The other numbers are broadly correct. I did find the video totally weird (doom background…
    shabaz over 6 years ago in reply to mrlvy +3
    Hi Matthew, The example you give doesn't seem to be a reason to 'stay away' from senseair products. If anything, I appreciate that they made this information available to the layman. mrlvy wrote: WARNING…
  • kas.lewis
    kas.lewis over 9 years ago +2
    K30 CO2 Sensor is one I have running full time in my room (part of my LivPi ). It auto calibrates using an interesting method. Its also not to costly for a full module (depending on your idea of costly…
    mrlvy  wrote:
    it claims that CO2 levels over 0.5% (5000ppm) are deadly to humans at
    https://youtu.be/HutR7V0SVn8 &t=2:36
    Well, that's technically true I'm afraid. Levels beyond about 5000 ppm can be deadly.. depends what the narrator meant when he used the word about, and how you measure it surely, and on whom - I sure wouldn't want to test a sustained 5000 ppm on a baby, or where it peaked way beyond that, but the average was 5000 ppm.
    You're reading way too much into a marketing video.
    The products might or might not be bad, I don't know - but certainly your conclusion "WARNING: you might wanna stay away from senseair products!" makes no sense - no engineer that I know of would use a single marketing video to support that. Have you tested the products to back up your "warning"?
