Sensors
Sensors
Sensor Forum Temperature sensor to put into water
  • Replies 11 replies
  • Subscribers 352 subscribers
  • Views 4544 views
  • water_proof
  • temperature sensor
koudelad
koudelad over 8 years ago
I would like to ask for recommendation of a temperature sensor to put into water. I have two household (amateur) applications in mind, one for drinkable and one for non-drinkable water. Temperature range is between ca. -10 and +120 centigrade, precision needed ca. +/- 1 centigrade. Something with a one or two meter cable would be perfect.
I was thinking about some DIY variant, but I am afraid of adding unnecessary thermal capacity to the sensor and shifting the original scale off. Last time I used LM75A LM335, just the non professional solder joints shifted the measured value to ca. -4 centigrade.
Thank you,
David
EDIT: I meant analog output LM335.
    mcb1 over 8 years ago +3
    I've always stayed away from using analogue sensors. One reason is the scale is not always linear ... well at least in the product I fixed with them in. I tend to always head to the DS18B20 with it's waterproof…
    jw0752 over 8 years ago +2
    Hi David, If you are serious about the need for measuring temperatures above 100 degrees C you may need to go to a sensor like those used in sterilizers. https://www.rpiparts.com/PartPage.asp?equip=2&oem…
  • ninjatrent
    ninjatrent over 8 years ago in reply to mcb1 +2
    I just purchased a waterproof DS18B20. It cost about US$10
  • neilk
    neilk over 8 years ago in reply to koudelad
    I have used DS18B20s quite a few times. They are very easy to use, already well calibrated and if you are using more than one, they give values which are consistent with each other.
    I bought mine from ebay,
    Neil
