Sensors
Sensors
Documents Inductive Sensing Possibilities
  • Author Author: joeman
  • Date Created: 28 Feb 2014 7:33 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:49 AM
  • Views 1477 views
  • Comments 5 comments
Inductive sensing offers new possibilities for the detection of conductive materials. Among its many uses, it can be utilised for:
  1. Detection – for example, a washing machine could conceivably detect if someone accidentally left change in their trouser pockets.
  2. Control – because of the unique sensitivity of inductive sensors, they could be used in the creation of precision controls.
  3. Input – rather than have distinct metal keypad with buttons, a flat metal surface with an inductive sensor could perform the same function; this approach implies less parts to go wrong.
  4. Measurement – these sensors can be used to detect conductive materials in an area or on a person.
  • sensing
  • inductive_sensing_challenge
  • input
  • detection
  • control
  • measurement
  • inductive
    Could this be used to measure the normal velocity of a surface in the audio frequency range 50 - 10,000Hz?
    mcb1 over 12 years ago in reply to Workshopshed
    If you had to climb in and out of a washing machine before each flight that might make airport security more interesting
    If they then turned it on, they wouldn't need the sick bags on the plane.image
  • Workshopshed
    Workshopshed over 12 years ago in reply to mcb1
    mcb1 over 12 years ago in reply to vsluiter
    Well put Victor.
    My washing machine uses a metal drum, so I can see the change detection working well.
    At work we have these biological monitors that usually detect things faster than the computer, and the domestic monitor at home works well for my washing.
    ... less parts to go wrong.
    ... let me see, a simple switch based device, or a board full of electronics that is sensitive to variances in temperature, users fingers and the amount of metal rings they have on, or the poor old person with Arthritis that is unable to properly open their hand.
    I think I'll plug for the keypad each time.
    I love Airport scanners, you now have to empty your pockets, take off your belt, and shoes if you wear safety shoes, as well as any jewellery.
    We need one at every public entrance to a building.....
  • vsluiter
    vsluiter over 12 years ago
    What is the purpose of this document? It could lead to something from TI, as they have their LDC1000 inductance measurement chip
