Sensors
Sensors
Quiz Strain Gauges Quiz
  • Author Author: pchan
  • Date Created: 8 Aug 2022 5:41 PM Date Created
  • Last Updated Last Updated: 4 Jun 2024 7:46 PM
  • Views 17442 views
  • Likes 16 likes
  • Comments 69 comments
Strain Gauges Quiz
Strain gauges are used to measure strain in several applications, including aerospace, transportation, industrial and more. Test your knowledge with our quiz on strain gauges.
profile image
sponsored by sponsor logo
Quiz | Sensors | Industrial Automation | Resource | Transportation & Automotive
Strain Gauges Quiz
Strain Gauges Quiz Score 100% on our Strain Gauges Quiz and leave your feedback as a comment to earn this badge...
To earn the Strain Gauges Badge, score 100% on the quiz and leave your feedback on the quiz as a comment.
  • e14quiz
  • omega
  • strain gauges
  • maxpowerr
    maxpowerr over 4 years ago +1
    Is it possible to make a water level indicator on Strain gauges?
  • ralphjy
    ralphjy over 4 years ago +1
    Another informative quiz. I really haven't used strain gauges in any of my projects, so far...
  • navadeepganeshu
    navadeepganeshu over 4 years ago +1
    Interesting quiz! Is there a document to read through before attending this quiz? Used to see in earlier quizes,...
  • FrodoH
    FrodoH over 4 years ago
    I have never used optical strain gages but they are compelling.
  • Sasza
    Sasza over 4 years ago
    Strain guages are very intressting technic for mechanicalmensurment.
  • sandeepdwivedi17
    sandeepdwivedi17 over 4 years ago
    nice quiz
  • jelektro
    jelektro over 4 years ago
    Another opportunity to broaden my knowledge.The difficulty of the quiz is quite high so I had to use the training resources.
  • sxaw_VSP
    sxaw_VSP over 4 years ago in reply to maxpowerr
    Possible, but could be very troublesome depends on your application. If you only wish to know if the water hit the desired level or not, you can mount the gauge on a material that would slightly bent (but not over-bent as gauge has its max. elongation) and put it parallel to water surface at the desired level location. The gauge resistance would be altered when water hit the level & bend the substrate.
    Otherwise, you will need to use the gauge to measure the overall weight of the water, a.k.a use a load cell. You might also think using the water pressure but the difficulty is on finding the right substrate that is sensitive enough to curve the right amount when the pressure change while not breaking the strain gauge. Using a force sensitive resistor or piezoresistive film is much robust & cost effective in this case.
  • ravi kondeti
    ravi kondeti over 4 years ago
    brings back the suprises I had when I first saw a strain gauge manufactured by Tokyo Measuring Instruments Laboratory
  • lime918
    lime918 over 4 years ago
    very useful info
  • Frederick_Analysis
    Frederick_Analysis over 4 years ago
    I will need strain gauges in a future project. I hope I win!
  • kmikemoo
    kmikemoo over 4 years ago
    Great quiz.  These are definitely on my "To Do" list.  Someday.
  • obones
    obones over 4 years ago
    This brings back memories from my uni years where we built a 2.5m tall rocket with strain gauges all over the structure...
