Test & Tools
Test & Tools
Forum EXTECH INSTRUMENTS  461957  PHOTOELECTRIC SENSOR, 1/8 DIN PANEL TACHOMETER with NI USB DAQ
  • Subscribers 386 subscribers
  • Views 265 views
Hi all,
I'm Fadz. Actually I'm looking for a tachometer with sensor to be use with NI USB DAQ in measurement process like measuring motor speed or measure distance of an object. From this site, I found a tachometer device which quite interesting and relate to my interest. What am I worry is, does this tachometer can be connect to NI USB DAQ for an example NI 6008 to acquire the signal? Or there's another type of tachometer which is more suitable to my application? Can anyone help on this?
Thank You,
tachometer--> http://www.farnell.com/datasheets/1469130.pdf?_ga=1.83433046.1351398480.1470110932
  • kulky64
    0 kulky64 over 10 years ago
    Should be possible to connect this sensor to NI USB-6008. It has NPN transistor output and requires 10-30V DC power. Check specs here:
    https://www.instrumart.com/assets/Extech-photoelectric-sensor-manual.pdf
