Test & Tools
Test & Tools
Forum Any recommendations for an entry level 3D printer?
  • Replies 13 replies
  • Answers 8 answers
  • Subscribers 387 subscribers
  • Views 3202 views
  • 3d pritning
  • 3d cad
genebren
genebren over 8 years ago
I am looking to get started in 3D printing.  I am looking for a relatively inexpensive and easy to use printer to start learning with. Any ideas and/or recommendations as to model, features or accessories that would be important? Also any thoughts about necessary software tools would be appreciated.
Gene
  • vlaine
    vlaine over 8 years ago +6 suggested
    I have a cheap Zonestar Prusa that I purchased from Aliexpress. I paid $200 if I remember well. It is very good and gives me impressive result. You have to purchase a printer wit a heated bed and auto…
    dougw over 8 years ago +5 suggested
    I have tried several printers including Cel Robox, Tivo Tornado and Anycubic I3 Mega. each has some nice features an some quirks. They all have features I need like heated bed that auto-releases when it…
  • rsc
    rsc over 8 years ago +5 suggested
    Hi Gene, I wanted to build my own, but without having to spec out all the parts myself, so I purchased the SeeMeCNC H2 kit https://www.seemecnc.com/products/h2-delta-diy-3d-printer-kit It works rather…
  • jeffersonpham
    0 jeffersonpham over 8 years ago
    I  have a Prusa clone that I got from HE3D. It’s their EI3 Dual extruder with auto Z-leveling and large heated bed.
    I Also bought the Double Z-axis so I could get more stability.
    I Love this printer, it was a little bit tricky to set up at first, but once I got it going and leveled, it prints amazingly well.
    http://s.aliexpress.com/EraErAbQ
    I Got it for around $350 dollars.
    The heated buildplate in the large version has a 200mm x 280mm x 200mm build volume which is pretty large and the power supply at 24V heats up pretty evenly.
    The dual extruder also adds a ton of flxability because I can print soluble filaments and get extremely detailed parts without having to remove supports.
    Good luck!
  • gam3t3ch
    0 gam3t3ch over 8 years ago in reply to jeffersonpham
    I found for the most part the best deals were on aliexpress for printers over other sites picked up mine on there for a few hundred use mainly pla bed is only 12v so takes a bit to heat wont reach the temps for abs printing even in an enclosure so think I might have to look at getting another and that one there you posted looks like it would fit my needs.  Thanks for posting the link to your suggested always good to hear what others think of their printers.
  • gsgill112
    0 gsgill112 over 8 years ago
    Have you checked Banggood / Aliexpress. there are pretty decent deals on chinese 3D printers, starting from 120-150 $
    //guri
