Test & Tools
Test & Tools
Forum Oscilloscope
  • Replies 23 replies
  • Subscribers 379 subscribers
  • Views 6355 views
  • scope
Oscilloscope
AminAmin
AminAmin over 3 years ago
I have oscilloscope Voltcraft Dscope 707.
I can,t found any data of Scope.
You help me for bandwidh of Scope?
    Jan Cumps over 3 years ago +1
    I couldn't find the bandwidth. I did find some info in a French technical magazine, Electronique Pratique N° 214 1997.05 . Oscilloscope à mémoire Dscope 707 Voltcraft Oscilloscope portable combiné…
    shabaz over 3 years ago in reply to AminAmin +1
    You could just open it up, to see what parts are used. Or apply known signals and see what the approximate bandwidth could be. Its quite old, no-one might have scanned any user manuals or datasheets online…
  • Andrew J
    Andrew J over 3 years ago +1
    I think the best thing to do would be to contact Conrad directly: https://help.conrad.com/hc/en-gb/requests/new
  • AminAmin
    AminAmin over 3 years ago in reply to Jan Cumps
    shabaz over 3 years ago in reply to Jan Cumps
    It's in Francs?!
    Ah, just saw the year... 1997
  • AminAmin
    AminAmin over 3 years ago in reply to shabaz
    Found any data? Send for me
    You could just open it up, to see what parts are used. Or apply known signals and see what the approximate bandwidth could be. Its quite old, no-one might have scanned any user manuals or datasheets online. It might have sold in very low volume at that high price but I'm speculating. You might have the 255th one ever sold if they started serial numbers at 810000.
  • Andrew J
  • AminAmin
    AminAmin over 3 years ago in reply to Andrew J
    Conrad no data of old produce.I send  message for conrad.
    Does it have a BNC socket? I can't see one. In any case, you could connect this device up to any audio source (e.g. PC headphone output) and generate a tone, to see if it works to 20kHz. Or use a 555 chip and see if it works to a few hundred kHz. There are plenty of ways to find our for yourself what the bandwidth is.
  • AminAmin
    Yes,have BNC
  • AminAmin
    Hello jan
    I fined data of Scope 707
    Bnd widh of scope is 100 khz!
    Very low bnd widh
    Fnirsi 1C15 is better or fnirsi 5012h?
    Impressed it reaches 100 kHz! I was guessing 10 kHz from the look of it.
    There's a review of the 5012h here: https://www.youtube.com/watch?v=SIH48bIUU00
    I only watched the last 2 minutes of it, it doesn't seem great (and the 1C15 looks worse),
    However, both of them will likely be a lot better than the 707, but that's an extremely low bar (single channel 100 kHz is of very limited use).
    What's your use-case and your budget? A decent 'scope will be closer to 150 euro. However if all you care about is approximately seeing the presence/absence of a signal with no significant accuracy or reliable triggering, then you could just about get any cheap 'scope such as the ones you indicate, and it will be better than the 707 as mentioned.
