Test & Tools
Test & Tools
Forum Weirdest Tool
  • Replies 29 replies
  • Subscribers 388 subscribers
  • Views 6335 views
  • doug wong
  • weird tool
  • useless tool
  • unusual tool
Weirdest Tool
dougw
dougw over 8 years ago
There has been an interesting focus lately on tools and work benches. I think it would be intriguing to have members show pictures of the weirdest or most unusual or most useless tools in their kit.
Do you have a convoluted screw driver or a set of misshapen pliers or a Smith chart slide rule or an abacus with a digital readout or a combination magnet/flashlight/scalpel? If so please share....
  • neuromodulator
    neuromodulator over 8 years ago +10
    This is a machine to cut thin tissue slices called "microtome". I suspect its from around the 50s. I'm currently trying to restore it...
  • fmilburn
    fmilburn over 8 years ago +9
    The photo below shows the front and back of a transmission band adjustment wrench for a Model T Ford that belonged to my father. He was always tinkering and had all sorts of interests. I think we got a…
  • fmilburn
    fmilburn over 8 years ago in reply to 14rhb +9
    14rhb wrote: Hi Gene, That hacked tool looks like it should be used for fencing - perhaps removing the heavy gauge staples holding wire to posts? Rod I think you might be right Rod. These are my father…
    jw0752 over 8 years ago in reply to neuromodulator
    It looks like your pictured pump will pump as many as 4 separate lines simultaneously. The were many occasions where we saw this type of pump used in the Oral Surgery clinics when we were servicing dental equipment. Pretty cool technology.
    • Vote Up +5 Vote Down
  • neuromodulator
    neuromodulator over 8 years ago in reply to jw0752
    Yes it supports 4 simultaneous lines... These pumps are used a lot in biological labs, this one specific came from a neuroscience lab...
  • neuromodulator
    More scientific instruments... This one is a transilluminator, its a strong source of UV radiation that is used in molecular biology to make stuff fluoresce. My plan is to adapt it to make PCBs...
    • Vote Up +7 Vote Down
    DAB over 8 years ago in reply to neuromodulator
    I used a very simple microtome in High School.
    A friend of mine had one and we were both into chemistry and biology in those days.
    Put in a bug, add paraffin, let cool, use razor blade to make thin slices.
  • snidhi
    snidhi over 8 years ago
    I found a weird tool in my lab. In-house made by a bachelor student 20 years ago.
    but now it has been rendered pretty much useless.
    Designed to strain the pins of through hole components before soldering.
    • Vote Up +8 Vote Down
    DAB over 8 years ago in reply to snidhi
    A very useful tool in its day.
    DIP pins always had a tendency to get bent.
  • snidhi
    snidhi over 8 years ago in reply to DAB
    yes I can totally understand. Even today the DIP packaging has angled rails on the sides for the pins which are not exactly 90 deg but extended.
    I will have to say that I did use this tool a few times whenever I had a DIP device to do some quick soldering and prototyping.
    jw0752 over 8 years ago in reply to snidhi
    I have a little black plastic pin straightener that the Radio Shack used to sell and I use it all the time. you have the professional model and I really like it.
    dougw over 8 years ago in reply to rsc
    I could use that for reaming out pumpkins...image
