Test & Tools
Test & Tools
Forum Clearance - 30v 3A TENMA PSU
  • Replies 23 replies
  • Subscribers 387 subscribers
  • Views 4007 views
  • bench psu
  • tenma 72-2705
14rhb
14rhb over 7 years ago
I regularly look through the clearance lines on CPC Farnell (a UK subsidiary of Farnell/Avnet) and currently they have a Tenma 30v/3A PSU for £51.84 (incl. tax and shipping)....not bad if someone is looking for a reasonable entry level PSU.
See https://cpc.farnell.com/tenma/72-2705/power-supply-0-30v-programmable/dp/IN0763769
Rod
    shabaz over 7 years ago +3
    Thanks for the info! That looks useful, and I could do with a small linear supply.. it's got fairly accurate readback capability it seems, and also the supply is programmable.. I could not resist at that…
  • stevesmythe
    stevesmythe over 7 years ago in reply to shabaz +3
    I have succumbed too. After all, it was my birthday last week (honestly). When I first looked, there were only two in stock, so I thought I'd better get a shift on!
  • stevesmythe
    Thanks! I hesitated before ordering and missed the cut-off, so mine won't arrive today. I'm glad there is a manual (even with typos and mistakes). I wasn't sure if there would be. My power supply needs…
  • abrain
    abrain over 7 years ago in reply to shabaz
    Hi Shabaz, that’s a nice set of measurements! I was wondering what you’re using for the 3A load? I’ve got a project driving a very inductive load at a constant current of around 2A using PWM at around 500Hz, and want an electronic load for testing with, so any recommendations would be much appreciated!
    A
    shabaz over 7 years ago in reply to abrain
    Hi!
    The constant current was using a BK8600 load (review here), it's got an easy-to-use front-panel interface, and simple to automate if desired too. If it's for personal use, there's a lower-cost Tenma load, but I've not tried it.
    It's my third BK Precision piece of equipment, it seems very usable to me. Most of the electronic loads (including the Tenma one it seems) use large binding posts, so normal 4mm banana test leads may not fit, but the end of the test lead could be cut off and a M6 lug crimped on.
  • abrain
    Thanks Shabaz, I’ll take a look! I’ve got a BK Precision signal generator and am very pleased with that, so am likely to stick with the brand too.
    A
