Test & Tools
Test & Tools
Documents Organize Your Workbench Wishlist
  • Author Author: dychen
  • Date Created: 10 Feb 2022 4:20 PM Date Created
  • Last Updated Last Updated: 1 Apr 2023 2:10 PM
  • Views 17436 views
  • Likes 13 likes
  • Comments 52 comments
Cable Bundle with Toilet Paper Roll
After a while, everyone's workbench starts to get cluttered with nests of cables, tools, tiny components and more. Thankfully, there are a lot of products designed specifically for engineers and makers that help organize the loose parts and cables, and give your bench a tidy and professional appearance. Time spent searching for things will be cut down dramatically once everything has its own little compartment.
Cable Management
Over the years, engineers and makers typically build large nests of cables. Without proper organization, this can make any kind of troubleshooting a nightmare. Walking barefoot or on your knees on cables gets a little annoying after a while.
Label Maker
The first step in organizing cables is labeling. It can be a pain to print a label when you just want to plug in and go, but it eliminates the time wasted later when you need to trace each cable to figure where it goes.
Brady Label Maker
Label Maker
Barcode Scanner
Many label makers can print barcodes. If you've got a lot of cables, a barcode scanner makes it one step easier to figure out what they are.
Barcode Scanner
Barcode Scanner
Wire Marker
If you have a bundle or a snake connecting instruments with multiple channels, wire markers are a great way to go.
Wire Marker
Wire Markers
Clip-in Cable Marker
Cable marker
Cable Marker
Heat Shrinkable Wire Marker Sleeves
Cable Tie
Cable ties or zip ties are very handy; an inexpensive way to quickly bundle up unruly cables.
Cable Tie
Cable Tie
Cable Tie Tension Tool
Rather than doing it with your fingers, you can grab a cable tie tension tool. They cut and tighten in one press of the lever.
Cable Tie Gun
Twist Lock Cable Tie
Twist lock cable ties bundle your cables with a convenient twist. They're also reusable, though I guess zip ties are also technically reusable (as long as the new bundle is smaller than the last).
Spiral Wrap
Spiral wraps make it easy to make a bundle out of a group of cables. This is something I've previously done using duct tape, which, of course, only sounds like a good idea.
Spiral Wrap
 Spiral Wrap
Cable Reel Holder
Cable reels are easier to store and manage than coils lying on the floor. If you deal with a huge amount of cables, cable reels make organization easier.
Cable Reel Holder
Cable Reel Holder
Cable Spool Rack
Most engineers and makers have to dig in their drawers to find the right cable spool; make things easy, and put them on a rack!
Cable Spool Rack
Cable Spool Rack
Jumper Assortment
Having a box that is divided into sections is much easier than having all your jumpers in the same shoebox (along with loose resistors and capacitors).
Jumper Assortment
Jumper Assortment
Component and Tool Storage
Speaking of resistors and capacitors, another source of of clutter is the large amount of tiny components lying around on every bench. Add surface mount components to that and we've got ourselves a serious problem!
Storage Cabinet
Every engineer or maker absolutely needs one (or twenty) cabinet with several small compartments. This saves untold hours in reading resistors.
Storage Cabinet
Storage Cabinet
ESD Cabinet
For ESD sensitive components, an antistatic cabinet is required.
ESD Cabinet
ESD Cabinet
ESD Bags
With some of the more sensitive components, it might be worthwhile to have some ESD bags on hand.
ESD Bags
Antistatic Bag
Portable Tool Case
Now onto our tools, because I've stepped on my pliers barefoot for the very last time! You've probably already got a cabinet for your tools, but a portable tool case is very handy for tools that you might need to carry around.
Tool Case
Portable Tool Case
  • clean
  • organize
  • giveaway
  • cabinet
  • wishlist
  • cables
  • workbench
  • wolfgangfriedrich
    wolfgangfriedrich over 4 years ago +2
    Cables don't like to be folded, so coiling them up would be the natural way to store them, but they tend to not stay in that form on their own. Adding one or more "bread bag plastic clip" (I am sure there…
    dougw over 4 years ago +1
    I'm not really proud of my work spaces - less than 6 people in the world have ever seen this one in person, but hundreds of projects have been built here. This is where I solder PCBs and cables. If you…
  • ralphjy
    ralphjy over 4 years ago +1
    Although my work areas and computer desks are normally quite a mess, I do try to organize between projects - although there almost never seems to be any time in between . For components like resistors…
    dubbie over 4 years ago in reply to colporteur
    I'm impressed with your perception. This is pretty much how it is. The further away from me the older I know it is. It isn't infallible as occasionally I have to look for something and then everything gets a major upheaval and the temporal locality aspects gets mixed up, but just give it a few months and order will be re-established.
    Dubbie
  • robogary
    robogary over 4 years ago in reply to colporteur
    The cardboard does gets notes written on it, altho I try to use the post it notes. The post it notes seen on the skirt are material lists needed for each of the robotic's club different events for the late winter/spring. After the event, I can just throw away the post it note.  The project area can use some downsizing.
    The cats like to chew on the cardboard skirt, so it gets replaced periodically, .....after I checked for needed scribbles.  :-)
    One of the cats is in the photo, they have to investigate every sound and move around the table.
    dubbie over 4 years ago in reply to aspork42
    I like the six screens. I think if I had six screens I would be more likely to try and watch six films at once rather than do any useful activity.
    Dubbie
    dubbie over 4 years ago in reply to robogary
    This looks like my kind of organised chaos.
    Dubbie
  • misaz
    misaz over 4 years ago
    One of my best idea in my life (and very cheap) for storing components was "invention" of these paper boxes:
    I printed them in A5 (not a standard A4 form factor) from the following template (it is also bundled as attachment in Word format if you want to do it yourself):
    After printing you can make them more robust using glue or I use simple office stamper as you can see above. Then I used these boxes in larger box for sepearating components. It worked well for years. Currently I am migrating to cheap plastic aliexpress boxes which offers similar performance.
    dougw over 4 years ago in reply to colporteur
    You nailed it - clutter on the shelf blocks light. I have tried several lighting augmentations - still planning better solutions.
  • colporteur
    colporteur over 4 years ago in reply to robogary
    The cardboard lament top with side skirts is a great idea. How often does it get used to record notes? That is just too convenient to not write on! I confess that is a lot in one area.
  • robogary
    Please, if you are squeamish, or have young women or children looking over your shoulder, you should look away. These photos arent pretty.
    I have a workshop, but it is filled with big power tools ( qty 9 kinds of power saws) , and all the needed stuff for house maintenance, cars, yard, painting, etc.
    My "cleanroom workbench"  is a ping pong table. My components storage are plastic drawer stacks from when my kids were young and living at home.
    Now they are mine , I had last dibs before they were to go in the trash.   :-)  Other projects and parts are in Tupperware under the ping pong table.
    Before making judgements on the mess, and in my defense, please understand, my robotics & makers club did a Raspberry Pi Jam today ( dont care if RPI.org sanctioned jams or not).  I 'm showing homemade robots for an elementary school next week. We will do an Arduino Week / Robot week celebration at the end of the month to prep for, .
    and I'm starting on a road test, and trying to fix a donated 3D printer.
    The last photo is especially disturbing - a bag full of resistors. If I dont find what I need in the plastic box, I gotta spend time searching thru that bag  :-(
    resistors, transistors, and MOSFETs.....ohhh, my....
  • ralphjy
    ralphjy over 4 years ago in reply to colporteur
    Yes, that is carpet - I have to be careful about ESD if we have low humidity days in the winter, but it hasn't been much of a problem.  I don't have a basement, so my work area is an "extra" room on the second floor that is accessed through my computer room.
  • colporteur
    colporteur over 4 years ago in reply to aspork42
    The hole idea is great. How big a hole did you find worked? I guess we don't have to worry about 25pi9nDB printer cable connectors fitting through the hole anymore?
