Test & Tools
Test & Tools
Documents Organize Your Workbench Wishlist
  • Author Author: dychen
  • Date Created: 10 Feb 2022 4:20 PM Date Created
  • Last Updated Last Updated: 1 Apr 2023 2:10 PM
  • Views 17457 views
  • Likes 13 likes
  • Comments 52 comments
Cable Bundle with Toilet Paper Roll
After a while, everyone's workbench starts to get cluttered with nests of cables, tools, tiny components and more. Thankfully, there are a lot of products designed specifically for engineers and makers that help organize the loose parts and cables, and give your bench a tidy and professional appearance. Time spent searching for things will be cut down dramatically once everything has its own little compartment.
Cable Management
Over the years, engineers and makers typically build large nests of cables. Without proper organization, this can make any kind of troubleshooting a nightmare. Walking barefoot or on your knees on cables gets a little annoying after a while.
Label Maker
The first step in organizing cables is labeling. It can be a pain to print a label when you just want to plug in and go, but it eliminates the time wasted later when you need to trace each cable to figure where it goes.
Brady Label Maker
Label Maker
Barcode Scanner
Many label makers can print barcodes. If you've got a lot of cables, a barcode scanner makes it one step easier to figure out what they are.
Barcode Scanner
Barcode Scanner
Wire Marker
If you have a bundle or a snake connecting instruments with multiple channels, wire markers are a great way to go.
Wire Marker
Wire Markers
Clip-in Cable Marker
Cable marker
Cable Marker
Heat Shrinkable Wire Marker Sleeves
Cable Tie
Cable ties or zip ties are very handy; an inexpensive way to quickly bundle up unruly cables.
Cable Tie
Cable Tie
Cable Tie Tension Tool
Rather than doing it with your fingers, you can grab a cable tie tension tool. They cut and tighten in one press of the lever.
Cable Tie Gun
Twist Lock Cable Tie
Twist lock cable ties bundle your cables with a convenient twist. They're also reusable, though I guess zip ties are also technically reusable (as long as the new bundle is smaller than the last).
Spiral Wrap
Spiral wraps make it easy to make a bundle out of a group of cables. This is something I've previously done using duct tape, which, of course, only sounds like a good idea.
Spiral Wrap
 Spiral Wrap
Cable Reel Holder
Cable reels are easier to store and manage than coils lying on the floor. If you deal with a huge amount of cables, cable reels make organization easier.
Cable Reel Holder
Cable Reel Holder
Cable Spool Rack
Most engineers and makers have to dig in their drawers to find the right cable spool; make things easy, and put them on a rack!
Cable Spool Rack
Cable Spool Rack
Jumper Assortment
Having a box that is divided into sections is much easier than having all your jumpers in the same shoebox (along with loose resistors and capacitors).
Jumper Assortment
Jumper Assortment
Component and Tool Storage
Speaking of resistors and capacitors, another source of of clutter is the large amount of tiny components lying around on every bench. Add surface mount components to that and we've got ourselves a serious problem!
Storage Cabinet
Every engineer or maker absolutely needs one (or twenty) cabinet with several small compartments. This saves untold hours in reading resistors.
Storage Cabinet
Storage Cabinet
ESD Cabinet
For ESD sensitive components, an antistatic cabinet is required.
ESD Cabinet
ESD Cabinet
ESD Bags
With some of the more sensitive components, it might be worthwhile to have some ESD bags on hand.
ESD Bags
Antistatic Bag
Portable Tool Case
Now onto our tools, because I've stepped on my pliers barefoot for the very last time! You've probably already got a cabinet for your tools, but a portable tool case is very handy for tools that you might need to carry around.
Tool Case
Portable Tool Case
  • clean
  • organize
  • giveaway
  • cabinet
  • wishlist
  • cables
  • workbench
  • wolfgangfriedrich
    wolfgangfriedrich over 4 years ago +2
    Cables don't like to be folded, so coiling them up would be the natural way to store them, but they tend to not stay in that form on their own. Adding one or more "bread bag plastic clip" (I am sure there…
    dougw over 4 years ago +1
    I'm not really proud of my work spaces - less than 6 people in the world have ever seen this one in person, but hundreds of projects have been built here. This is where I solder PCBs and cables. If you…
  • ralphjy
    ralphjy over 4 years ago +1
    Although my work areas and computer desks are normally quite a mess, I do try to organize between projects - although there almost never seems to be any time in between . For components like resistors…
    beacon_dave over 4 years ago
    Just about everything comes with an adapter, custom breakout cable, or other accessory these days and once you open that one-use blister pack (and after reaching for the first aid kit) then you need to find a suitably-sized storage container if you want to keep everything together. That can get quite expensive and cause problems with the budget planning. Also it is sometimes difficult to find a container of just the right size, so you can then end up wasting a lot of storage/transport space storing/moving trapped air around. It would be nice to have foam inserts to stop stuff rattling around as well but more expense.
    dubbie over 4 years ago
    I came to an understanding with myself after I had retired that I don't really like organising my workspace and that I actively like it best when it is chaotic and confused. So any storage systems of labeling systems are of no value to me. I like it confused, I like it messed up and I generally start new projects from scratch so I do not re-use much and I generally just buy new what I need. It's not efficient but I just don't care anymore. My current workspace brings me great joy. The only organisation I could see when I looked at my desk (see photograph) is that generally I keep my hand tools near my right hand and the project I am currently working on near my left hand. I think that's about as organised as I get.
    And now it must be time for a cup of tea and to wash some plant pots so I can pot on my lavender cuttings I took last autumn.
    Dubbie
