Wearable Technology
Wearable Technology
Blog Christmas Hat: Finishing Touches
Join Wearable Technology to participate - click to join for free!
  • Author Author: brenyc13
  • Date Created: 13 Dec 2014 3:10 PM Date Created
  • Views 1433 views
  • flora
  • wearable_technology
  • christmas_hat
  • adafruit
  • haturday
brenyc13
brenyc13
13 Dec 2014
A post about adding felt decorative pieces and feathers.
Putting things on the hat
I was so excited about figuring out the look of the NeoPixel strip last week that I totally forgot to talk about soldering everything together. It was a pretty easy process. I sewed the Flora to the side of the hat (with a little glue on the back for added stability), soldered on the wires for the NeoPixel strip, and then used a clampy-hand-thing to secure each through-hole NeoPixel as I soldered them together. I tested that that my new NeoPixel jumble worked before soldering it to the Flora as well. No problems. Smooth sailing.
Fail of the Week
My initial design called for side-glow fiber optics edging felt shapes representing snowflakes and holly leaves. Even though I tried to work it out with two different kinds of fiber optic line, this was a no-go. No matter what I tried, it looked awful. After a few hours of trying to glue, sewing, and otherwise manipulate the fiber optic thread, I threw in the towel.
What then?
I still liked the idea of using felt pieces and feathers to disguise the Flora. So I went ahead and made a little Flora cover of felt that also covered the back two 5mm through-hole NeoPixels. When held against the hat, the felt diffused the light from behind in an interesting way. So I sewed some snap closures to secure it to the hat while still providing access to the board. But the "berries"--three 8mm through-hole Neopixels--ended up looking weird. So I disguised them as a feathery pouf and added some smaller feathery bits in the gaps to fully hide the electronics.
So the hat is done?
Nearly! I just need to tweak the code a bit. But I'm planning on wearing it to my company's Christmas party tonight.
    DAB over 11 years ago
    Good update Barbara,
    Sometimes you just have to try things out before you realize that it just won't work.
    Luckily you are resourceful enough to think of something else.
