Wearable Technology
Wearable Technology
Forum Which 6DOF IMUs should I be considering for my wearable smart glove? (details below)
Join Wearable Technology to participate - click to join for free!
  • Subscribers 51 subscribers
  • Views 3768 views
  • 6-axis imu
  • glove
  • imu
  • Wearables
bhaveshbytes
bhaveshbytes over 9 years ago
Hello element14 community!
I am working on a smart glove that picks up hand movements, and sends them to a processor for gesture recognition. I am looking for two 6DOF IMUs on the glove:
  1. An IMU on the index finger
  2. An IMU on the back of the palm (the "dorsum" of the hand)
The reason that the IMUs should be 6DOF and not 9DOF is that I will put a separate, common magnetometer on the wrist for global orientation.
Furthermore, I strongly prefer that the IMU has either a) on-board sensor fusion, or b) easy to use sensor fusion library for ARM Cortex-M series.
Here are a few I've found so far, although I'm hesitant to buy them because their devkits are so expensive:
  1. Bosch BMI055 (https://www.bosch-sensortec.com/bst/products/all_products/bmi055)
  2. Bosch BMI160 (https://www.bosch-sensortec.com/bst/products/all_products/bmi160)
  3. Invensense ICM-20689 (https://www.invensense.com/products/motion-tracking/6-axis/icm-20689/)
The reason I am not going for the MPU6050 from Invensense is that it looks like they are going to stop manufacturing it soon, and I will need large quantities in about a year's time.
Finally, the most important part: Here are some of the key specs I would like this IMU to fulfill:
  1. 200°/s or more gyro rate
  2. On-board sensor fusion OR easy to use, good sensor fusion library for ARM Cortex-M
  3. ±10g or more accelerometer range
  4. 200Hz or more sampling rate
  5. -40°C to 85°C or better temperature range
  6. 5mm x 5mm or smaller package
Hopefully that's enough info to get started. Please shoot me your recommendations, I would really appreciate it and it'll take this project one step further along the painful part selection phase. Thank you, and feel free to comment with any questions or requests for clarification (I might have overlooked something).
Bhavesh Kakwani
  • bhaveshbytes
    bhaveshbytes over 9 years ago +4
    EDIT: The comment below is out of date. I actually ended up going with the MPU-9250 which is again very similar to the ICM-20689 except it is 9DOF. I had to change because the MPU-9250 had much better…
  • bhaveshbytes
    bhaveshbytes over 7 years ago in reply to nhcz +1
    Hi Hari, please refer back to my comment to see my update with the edit. Basically, it was difficult for me to find the ICM-20689 on the market back then so I ended up choosing the MPU-9250 instead. It…
  • bhaveshbytes
    EDIT: The comment below is out of date. I actually ended up going with the MPU-9250 which is again very similar to the ICM-20689 except it is 9DOF. I had to change because the MPU-9250 had much better availability in the market at the time of purchase.
    I ended up going with the Invensense ICM-20689. It is part of the follow up line to the MPU-6050, which is itself a popular and high quality IMU. And its specs fit well for my project's requirements.
  • nhcz
    nhcz over 7 years ago in reply to bhaveshbytes
    Hey hi bhaveshbytes, how did ya program for this sensor? Is there a link from where I can get a library or methods to program using this sensor in a project? And also how is the performance?
  • bhaveshbytes
    Hi Hari, please refer back to my comment to see my update with the edit. Basically, it was difficult for me to find the ICM-20689 on the market back then so I ended up choosing the MPU-9250 instead. It is very similar to the MPU-6050 but just an upgraded version and it is a 9DOF IMU.
  • nhcz
    Thanks for the info!
