Wireless
Wireless
Blog Two way communication, double data rate possible
  • Author Author: Eavesdropper
  • Date Created: 22 Feb 2011 1:56 AM Date Created
  • Views 1242 views
  • on_campus
  • radio
  • wireless
  • university
  • filter
  • communication
  • transmission
Eavesdropper
Eavesdropper
22 Feb 2011
Two way, simultaneous, wireless communications over a single channel has been demonstrated by Stanford's researching engineers Jung Il Choi, Mayank Jain, and Kannan Srinivasan.
"Textbooks say you can't do it," said Philip Levis, assistant professor of computer science and of electrical engineering. "The new system completely reworks our assumptions about how wireless networks can be designed." But wait, I can talk and listen on my cell phone! The research team claims the way companies achieve this effect is much more costly and cumbersome than there method.
Transmission of a radio signal is much more powerful than what the device needs to listen to. Levis explains, "When a radio is transmitting, its own transmission is millions, billions of times stronger than anything else it might hear [from another radio], It's trying to hear a whisper while you yourself are shouting." They defeated this issue with a simple idea: "What if radios could do the same thing our brains do when we listen and talk simultaneously: screen out the sound of our own voice?" Similar to noise cancelling headphones, the transmitter filters out what it is sending. Immediately the incoming signal can be heard.
Levis explains a major use of the technology in the future, " With current systems, if two aircraft try to call the control tower at the same time on the same frequency, neither will get through. Levis says these blocked transmissions have caused aircraft collisions, which the new system would help prevent."
The now patented technology has the potential to double data rates in every communication system. The team continues to work towards extending the range and power of their device.
Eavesdropper
    DAB over 15 years ago
    It's amazing how some of the most simple solutions are right in front of us and we cannot see them.  Its like watching a magic trick, then seeing it explained and you see that it was obvious.
    This solution reminds me how we did gated laser pulses to see things at different distances through smoke and fog.
    Really cool solution.
  • Catwell
    Catwell over 15 years ago in reply to DAB
    For the most part, we all do what is easiest to make and works first. The more elegant solutions come much later.
    I have not heard much about this tech since I read about it here in Feb, 2011. We need more progress, faster.
    Cabe
  • Catwell
    Cabe
