Wireless
Wireless
Forum Remote controlled release mechanism underwater
  • Subscribers 218 subscribers
  • Views 2613 views
  • remote controlled
  • release
martinho11
martinho11 over 5 years ago
I am looking for some other point of views on how to solve this problem. A horizontal load in the water is connected to a rope frame by a clip that is manually unclipped/released in order to get reel the rope in on a boat. I am searching for some kind of signal, maybe ultra sonic signal, that will tell the mechanical latch to release while being perhaps 10-15 meters away. If you have any questions, let's discuss it below.
    DAB over 5 years ago +2 suggested
    An acoustic signal would be your best solution. Sound travels well underwater and you would need only a minimum signal strength to cover the distances you mentioned. You can use a low power design to control…
    0 DAB over 5 years ago
    You can use a low power design to control the clamp, you will just need to make sure everything stays dry.
    Could you attach a float to the clamp?
    If so, you could keep the electronics above water and only send down the clamp release signals.
    An above water solution would also open up a laser or RF trigger option.
    0 dougw over 5 years ago
    Is it feasible to run a second line, like a heavy fishing line, to pull a release on the clip?
    Is it feasible to have a device that crawls down the rope and hits a release lever, possibly like a mini torpedo that clips around the rope?
