Wireless
Wireless
Forum Ultrasound spread for detection
  • Subscribers 220 subscribers
  • Views 561 views
  • ultrasound
  • wireless
ZeroSizeObject
ZeroSizeObject over 15 years ago
Inspired by a simple ultrasound emitter/detector I saw at a tradeshow, I want to create one with a wide FoV. I can't be the first to want to do this, have you ever seen a project like this? If so, please post a link.
My project requirements:
1. A field of view (FoV) of 90 degrees or higher.
2. Low power, battery operated.
3. Microprocessor optional.
Zero
  • jvdberg@ieee.org
    0 jvdberg@ieee.org over 15 years ago
    Several ultrasound detection systems are (or were) on the market. When used as burglar alarm, the cheap ones have a bad reputation of giving many false alarms. Never point an ultrasound detection system to a window. A window is a very good reflector and is moved by the wind and sounds of outdoor trafic. This will give a high unwanted output from the detector. The better ultrasound systems have filters to separate the unwanted detections and only respond on the intended detection. The main problem is not the ultrasound speaker and microphone, but the filters to avoid unwanted detections.
  • ZeroSizeObject
    0 ZeroSizeObject over 15 years ago in reply to jvdberg@ieee.org
    JV,
    Could you point me in the right direction on sourcing ultrasound components?
    Zero
  • jvdberg@ieee.org
    0 jvdberg@ieee.org over 15 years ago in reply to ZeroSizeObject
    A quick look on the internet resulted in the following links. I have no experiences with the equipment mentioned here. A unit that is for sale as a kit can be found on http://www.kemo-electronic.de/en/Light-Sound/Ultrasonic/Kits/B214-Ultransonic-proximity-sensor.php A simple schematic can be found on http://www.explorecircuits.com/circuit/cir_ultrasonic_transmitter_receiver.htm http://www.explorecircuits.com/circuit/schematic/3.jpg As you can see there is no filtering at all. The unit only responds on an increase of signal-level. Units that look more professional can be found on http://www.maxbotix.com/
