Wireless
Wireless
Forum Discover WIFI SN8200
  • Subscribers 219 subscribers
  • Views 520 views
  • wi-fi
Looking through the SN8200 SNIC Serial Interface Specification.pdf 5.23 TCP or connected UDP packet received indication I have found the command SNIC_CONNECTION_RECV_CFM, but cannot find a value for this command. It is required as per
"Upon a successful reception of the report, the host application sends to the SN82xx the following reception confirmation. Indication Sequence is copied from the received indication." with ref to Table 58 Confirm: TCP packet received indication.
Please see pdf attached. Does anybody know what the value should be?
imageSN8200 SNIC Serial Interface Specification.pdf
    OK! I have found the information the command value is the IND value | 0x80.
    An indication of what is required is at the top of page 22 of the above attached pdf.
    Thanks if you looked.
    Dave.
