Wireless
Wireless
Forum QI at small currents 10mA
  • Subscribers 219 subscribers
  • Views 535 views
  • qi
I have device that needs only 10mA charging current. It working with stndard receiver coil. Question is can coil be much smaller with dimension and thickness because I do not need big currents?
This is useful as my device is very small to.
    Question is for QI wireless charging
    0 dougw over 12 years ago
    Hi Miroslav,
    The simple answer is yes, you can design a coil smaller than normal dimensions to work with Qi standard.
    You can use the following articles to get some idea of how to design a coil for your requirements:
    http://www.how2power.com/newsletters/1107/articles/H2PToday1107_design_TI_Sengupta&Johns.pdf
    http://www.ti.com/lit/an/slyt479/slyt479.pdf
    If you use reasonable assumptions you may also be able to find an adequate solution by trial and error, especially if you have the ability to measure to coil output. I have used a simple square spiral trace on a PCB with tuning capacitor to get useful results. Of course you will also need a Qi chip to perform communications and control.
    Doug
