Wireless
Wireless
Forum Has anyone tried 2.4GHz LoRa?
  • Subscribers 218 subscribers
  • Views 5212 views
  • ble
  • lora
  • semtech sx1280
  • 2.4ghz lora
ralphjy
ralphjy over 4 years ago
I had not heard of 2.4GHz LoRa until I came across the Semtech SX1280.  I was looking for a device or module that could do both LoRa and BLE.
It combines BLE and LoRa in the same transceiver by moving the LoRa frequency to 2.4GHz so that the antenna can be shared. Apparently it's been around for a couple of years. I was wondering if anyone on E14 has tried it and what their experience has been.
I have a RAK4631 that combines BLE with LoRa at the conventional frequencies (I use the US915 band).  It uses an nRF52840 for BLE and an SX1262 for LoRa - and uses separate antennas...  I was writing a blog post about it but it got sucked into the black hole of  moderation.
  • BigG
    BigG over 4 years ago +1
    I came across the HOPERF RFM99W module some time back but never got round to ordering them to try out... and yes you can use BLE and LoRa with single antenna... but note its only compatible at the BLE…
  • ralphjy
    ralphjy over 4 years ago in reply to BigG +1
    The SX1280/SX1281 are in distribution and the chip prices are reasonable - about $6. The lower priced dev kit is $75. There are castellated modules from EBYTE that are selling on Amazon and AliExpress…
  • ralphjy
    ralphjy over 4 years ago in reply to geralds +1
    Hi Gerald, The modules that you referenced are the standard sub GHz LoRa not the 2.4GHz. I am interested in looking at the LoRa/BLE hybrid capability using a single antenna. I want to get a sense of…
  • BigG
    I came across the HOPERF RFM99W module some time back but never got round to ordering them to try out... and yes you can use BLE and LoRa with single antenna... but note its only compatible at the BLE PHY layer. You'll have to do the rest or find a vendor that builds a compatible BLE stack for you.
    www.hoperf.com/.../RFM99W Specification.pdf
    I know you can order samples from them directly at a good price as I cannot see these modules on sale anywhere else...
    I think that's probably why so few people have tried and made noise about... but then again... there's probably others in the e14 community who have. I'm curious too.
  • geralds
    geralds over 4 years ago
    look for this similar LoRa modul:
    RFM98P 169/433/470MHz Enhanced Power RF LoRa Transceiver Module NEW!_LoRa long range transceiver module-Hoperf
    It operate at 169/433/470MHz (RFM98PW)  and 868/915MHz(RFM95PW) ISM band.
    The used controller on the demo kit is a PIC1615.
     https://www.hoperf.com/data/upload/back/20190305/RFMXXB_TOOLS.pdf
    A similar demo kit comes with a display
    https://www.hoperf.com/data/upload/back/20181122/HopeRF_RFDK_RFMxx_DEMO_V2.1_operation_manual.pdf
    Best Regards
    Gerald
  • ralphjy
    The SX1280/SX1281 are in distribution and the chip prices are reasonable - about $6.  The lower priced dev kit is $75.  There are castellated modules from EBYTE that are selling on Amazon and AliExpress, so I might try one of those - although it takes 4-6 weeks to get them from China.
  • ralphjy
    Hi Gerald,
    The modules that you referenced are the standard sub GHz LoRa not the 2.4GHz.  I am interested in looking at the LoRa/BLE hybrid capability using a single antenna.  I want to get a sense of the operational tradeoffs vs a unit that I have that uses 915MHz LoRa and BLE with separate antennas.
  • BigG
    BigG over 4 years ago in reply to ralphjy
    The RFM99W is at a similar price. Ah yes, forgot about the EBYTE SX1280 modules. Yes as you say, they're available on aliexpress etc. I've been dying to try them out. Thought they would work well for hacking a radio controlled car to give extra distance etc.
