Wireless
Wireless
Forum Passive RFID Tag
  • Subscribers 221 subscribers
  • Views 791 views
  • rfid_tag
Passive RFID Tag
giorgiogu
giorgiogu over 10 years ago
I was looking for a Passive 13.56MHz HF RFID tag.
is was looking at this:
http://uk.farnell.com/stmicroelectronics/srtag2k-dmc6t-2/nfc-rfid-tag-2kbit-13-56mhz-qfn/dp/2396469
But i'm a bit confused if it can be passive, so to be powered up only by the RFID reader, and what is the maximum distance the tag can be read from.
Thanks again for your help.
Giorgio
  • jadew
    jadew over 10 years ago
    It will vary, but don't expect more than a couple of cm.
    Edit: Missed your power requirements question. Yeah, it's powered directly by the reader.
  • giorgiogu
    giorgiogu over 10 years ago in reply to jadew
    Thank you for your help,
    Ideally i would need about 6cm range, is there any similar tag i could use?
    Thanks again
    Giorgio
  • the-dubster
    the-dubster over 10 years ago in reply to giorgiogu
    Larger tags contain larger antenna so increase the range, also a more powerful antenna (high gain) on the reader will push the distance out further without having to use active tags.
