    • Avnet Boards Community
Forum Schematic & PCB Netlist diverging - how to correct?
  • Subscribers 174 subscribers
  • Views 395 views
  • netlist
Hello
using eagle 5.11.0
My PCB & Schematic got disassosiated - the PCB contains an additional  N$12 - and I can't seem to get rid of it. - Is there a way to edit the Netlist - import it back - to get the schematic & pcb forward/backward anotation working again? Any other solution?
Much appreciated,
Pieter
netlist for Schematic
N$11     JP16     1        1          1
         P1       T        T          1
         U$2      17       17         1
N$14     JP32     1        1          1
         P1       V        V          1
         U$2      21       21         1
netlist for PCB
N$11     JP16     1
         P1       T
         U$2      17
N$12     P1       P
N$14     JP32     1
         P1       V
         U$2      21
  • Richard_H
    0 Richard_H over 13 years ago
    what happens when you type  SHOW @ N$12  in the command line? Anything you can see there?
    Richard
  • Richard_H
    Richard
    0 Former Member over 13 years ago in reply to Richard_H
    The pin high lights
    moving the connector does not show a track connected (i.e. other end of track ussually stays put)
    delete N$12 also generates an error message.(No SIGNAL)
    As the board is not complicated I was able to redo - I'm just not sure how this fault happened - I was busy swapping a lot of signals/pins.
    Appreciate the feedback -as the offending schematic and board were dumped - unfortunately nothing on my side to assist further. If it happens again I will request further assistance.
  • Richard_H
    0 Richard_H over 13 years ago in reply to Former Member
    in case that this happens again, feel free to send me the files by private email.
    support @ cadsoft.de  So I can check it.
    Richard
